Chevy Volt 200,000 Mile Club
Discussion in 'GM Hybrids and EVs' started by Jeff N, Dec 5, 2014.
  1. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    The first Volt on VoltStats.net to drive past 200,000 miles (72,000+ miles on battery charge).
    Change oil every 38,000 miles
    Rotate tires, replace as needed
    Only, failure was a front wheel bearing.
    Almost no noticeable battery range loss.
    First Chevy Volt To 200,000 Miles
    #1 Jeff N, Dec 5, 2014
    markabele and Jwservant like this.
  2. El Dobro
    El Dobro A Member
    7,106
    3,282
    Nice, congrats to the owner.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    36% EV ratio so, 72,000 miles on the battery.
    His lifetime fuel economy was 50 MPGe.
  4. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I'd say 36% EV is pretty good for someone whose commute is over 200 miles per day in a PHEV although 97.6% of VoltStat drivers had a higher EV percentage.
    As you should remember, the VoltStats MPGe calculation is based on EPA estimates since actual electric charging data is not made available to them through GM's OnStar web api. Still, 50 MPGe is much better than the vast majority of cars on the road.
    His car has been pretty reliable so far.
  5. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    I easily get 53+ mpg with no plug in.
    DBCassidy
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I'm surprised GM was able to make a decent car. My current usage pattern precludes my Prius reaching 200,000 miles or dropping to 50mpg. We'll see how long the wheel bearings last.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    I'm sure his mileage will go up if he raises the tire pressures and takes it out of Sport. ;)
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  9. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Sounds good but the guy with 99.8% EV has 63.5k miles on the battery.
    What would happen if he approaches 100k or 150k miles?
    Also his gas fuel economy is in single digit.
    A pure EV would have been better for him and a regular Prius would for the first guy.
    dbcassidy likes this.
  10. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    We'll just have to wait and find out how the battery does over longer time periods and EV driving range. When the degradation does begin taking a hit on range then the gas engine will be there to back him up on his commute.
    His 9 mpg on gasoline is largely from the car running engine maintenance every 6 weeks automatically for a few minutes to keep things lubricated. It's an insurance payment of sorts and has minimal impact to his overall results since the amount of gas is so small.
    At the time he bought his car there weren't many other options. If you look at his detailed monthly averages you see that he is driving 70-90 miles a day on average:
    Volt Stats: Details for Volt #2012-10318 (PLUG1N)
    In a LEAF that would have meant sometimes depending on the existence and availability of charging during his daily trip (charging at work etc.). Charging stations lose power sometimes during an occasional brief outage or equipment fails for a few days and needs repair. Requiring some added charge during a routine daily commute is risky.
    Trollbait likes this.
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    If he had a Leaf, it wouldn't do that.
    If he can get 99.8% EV with 37 miles range battery, Leaf with 75 miles range would work for him.
    He would use less electricity per mile without having to lug the gas powertrain around for 63.5k miles.
    That's all I am saying.
    iplug and irrational like this.
  12. Trollbait
    12,831
    And where he lives, it could be a lot cheaper to burn that gas than to rent or pay insurance on another car. Or he simply was more comfortable driving a Volt over a Leaf. Going by the complaints about Prius seats, comfort is an important consideration.
  13. Jeff N
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Ashlem likes this.
  14. Jwservant
    Jwservant Junior Member
    Santa Cruz
    The problem with the leaf is that after 36k miles the range drops down to 70 miles,and continues to drop as mileage goes up.Master certified leaf service advisor.
