Chicken dance not workin, options?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by metamorphosis, Feb 1, 2021.
  1. metamorphosis
    metamorphosis Junior Member
    22
    New Zealand
    My key is mostly fine but won't unlock with the button after unintentional water submersion for more than 2 minutes.
    However I can't get the car to go into programming mode for either of the two procedures for the chicken dance. It is a non-SKS black logo key. I ordered a couple of replacements from a reputable-looking dealer on amazon (cost $150 including postage to New Zealand).
    I'm wondering if my car (2005 gen 2) might have had too many keys assigned to it in the past - how would I know, and what are my options from this point, if even following the chicken dance with the video timing doesn't work?
    Thanks,
    Matt
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    JC91006 likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,980
    925
    Southern California
    Take it apart and clean it. In general if an electronic device has been submerged in water, and it wasn't distilled water, the best thing to do is to remove the battery (if at all possible) and rinse it thoroughly in distilled water, then let it dry thoroughly before adding power back. Otherwise the minerals and/or dirt present in the water will dry on the device and could cause problems like what you are seeing. Of course if a car was driven into a river or pool I am not suggesting dunking it in a big tank of distilled water. This advice is only for small electronic devices, like watches, phones, and key fobs.
  4. metamorphosis
    22
    New Zealand
  5. metamorphosis
    22
    New Zealand
    I cleaned it out and dried it as best I could (couldn't figure out how to take the casing apart without destroying it) by putting in a hot water cupboard overnight in a closed container full of rice. Took the battery out and replaced it at least. Don't want to mess with it any further until I have a replacement key. Otherwise no drive for me
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Yes, do a search (the feature is still working). Unknown if 'lite' is adequate, but there are plenty of options once you have the cable.
