Choosing a power meter
Discussion in 'Gen 5 Prime Charging' started by tovli, Oct 11, 2023.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    352
    275
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I only have a 120v receptacle available in my garage, so I charge my 2023 Prius Prime XSE at 120v 12A and keep track of each day's driving performance and charge consumption.
    I originally was using this $15 Mecheer PM01-US meter which I estimate reads 2% high:
    Mecheer PM01-US.jpg Note 10.99 kWh reading from the last charge
    Yesterday I also used a $12 SwitchBot Plug Mini A2:
    which is 2.4GHz WiFi enabled which gave this display of 10.53 kWh in the SwitchBot app:
    I stacked them with the Meecher attached to the wall, and the Toyota CCID plugged into the SwitchBot.
    The SwitchBot draws 0.8W, so the Meecher 10.99 kWh includes 0.01 kWh (13 hours * 0.8W / 1000 w/kW) drawn by the SwitchBot Plug Mini giving a Mecheer reading of 10.98 kWh drawn by the CCID for last night's charge. Previously I have tested the Mecheer meter to read 2% high but I have been using the readings without adjustment.
    The SwitchBot read 10.53 kWh this morning which is 4% lower than the Mecheer reading, so perhaps 2% lower than the actual but I'm going to just use the readings without adjustment.
    The SwitchBot meter is much more convenient to read and is the meter I am going to be using going forward.
    Yesterday's drive was 33.7 miles at a reported consumption of 4.7 mi/kWh using 80% of the EV mode battery capacity.
    I am using 10.6 kWh as the 100% EV mode capacity, and the car estimated the remaining charge as 20%:
    - Battery used: 80% of 10.6kWh = 8.48 kWh
    - Charging Loss Factor: 10.53 kWh wall / 8.48 kWh battery = 1.24x
    Charging with Level 1 CCID lost 24% to voltage conversion, heat, and battery cooling.
    (Charging with Level 2 loss is usually around 5%, so I could potentially save 30 cents per charge, maybe $90/year, but having a 240v receptacle installed would cost several hundred dollars right now.)
    vvillovv likes this.
  2. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    I have not figured out how to get that miles per KWH display on the Prius meter (I think its called the meter ?). Can you enlighten me ?
  3. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    Read recently in owners manual that the KWH/Mile display may be in PP with a Solar Panel roof. I don't have that option, so I don't have a KWH/Mile display option.
  4. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    I stumbled upon this in my PP without a solar roof. It only shows during EV mode and it replaces the miles per gallon display. If you have that one selected and then you enable EV mode, it should switch to showing miles per kWH.
    RandyPete likes this.
