Chosen Oil Viscosity...?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by GuardianGrayHalcón, Dec 6, 2023.
  1. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    HTHS makes a big difference in the main bearing wear. That's why GM revised back to 0w-40 instead of 0w20 on their pickup Trucks.
    Toyota engines are not known to have main bearing problems unlike BMW, VW, or GM.
    To compensate the thinner oil, most 0w-8 oil contains high amount of antiwear especially Borons. So, do not mess around with adding oil additives that mess the balance and optimum ratios of the additives and detergent.
    Toyota engine prones to piston rings clogging more. Viscousity Modifier (VM) % in 0w-40 or 0w-30 is higher than 0w20. VM tends to degrade faster and create deposit more.
    So choosing the oil viscousity depends where and how we use the car. Using 0w-30 or thicker is suitable in warmer climate or if we do towing or live in the mountains.
    Trollbait likes this.
  2. Hammersmith
    Hammersmith Senior Member
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm just going to point out that GM's switch to 0W-40 is only because of the defective crank journals. If they had been machined properly, GM would never have switched to 0W-40 for those engines. If you have one of those engines and it's been damaged bad enough to warrant replacement, the new engine with a correct crankshaft will be specced right back to 0W-20.
    Personally, I have absolutely zero worries running 0W-16 in my gen5. I wouldn't have had any problems even if Toyota had specced 0W-8 like the same engine in the Corolla. As long as the engine is designed with the thin oil in mind, the engine parts are made of quality materials, and the manufacturing process means the finished product meets or exceeds the design specs, I'm fine. I don't know how confident I'd be with a GM, Ford, BMW, MB, or Audi that specced 0W-16 or 0W-8, but I don't worry about Toyota. I'll just do my 6m/5k mile changes and sleep well at night. The only thing I could wish different would be if Valvoline made Restore & Protect in 0W-16 and 0W-8.
    Tande and johnHRP like this.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Keep in mind that the antiwear/extreme pressure/friction modifier (AW/EP/FM) additives are for the valvetrain and cylinders, which do or may operate in the boundary-lubrication regime. For bearings, you need a minimum HTHS viscosity to achieve a minimum oil-film thickness (MOFT), as they operate in the hydrodynamic-lubrication region. For the boundary-lubrication region, both the base-oil viscosity and AW/EP/FM additives are important.
    Boron additives these days are almost always dispersants, not antiwear additives, even though a while back some oils experimented with boron antiwear additives. Toyota has been using a lot of boron dispersants in their genuine engine oils (TGMO) after its sludge problem. ExxonMobil makes the TGMO in the US.
    johnHRP likes this.
  4. Trollbait
    12,829
    Is any non-Japanese brand recommending 0w16 or 0w8?
  5. Gokhan
    6,714
    2,672
    Paramount CA
  6. Trollbait
    12,829
  7. Gokhan
    6,714
    2,672
    Paramount CA
    Just as ILSAC is a consortium of American and Japanese car OEMs, ACEA is a consortium of Euro car OEMs. ACEA did not have SAE 0W-20 until recently, but now, it is common with Euro OEMs. If SAE 0W-16 is in ACEA now, some Euro OEMs will adopt it in the near future, as ACEA is nothing but a governing body of Euro OEMs.
    johnHRP likes this.
  8. johnHRP
    646
    189
    KA, DE
    Excel
    That is right, some Ford engines consume oil if we use higher viscousity because the cylinder wall cross hatch patten is designed for thinner oil. I also prefer whatever recommended by manufacturer for most engines application. The only thing to prevent me using 0W-8 oil is pricing and aftermarket availability. If I can find it with reasonable price for newest Camry, Yaris, or Crown, 0W-8 is the one to go.
    I do not know if Toyota still have engines with chronic oil consumption problems like 2010-2014 Prius/PriusV/Corolla hybird engines. I found that thicker oil does not help on those engines. Only more frequent oil changes (5-8k miles) with high quality full synthetic oil helps. I think GTL Pennzoil, Shell, Quaker State Ultra Platinum helps because of more robust base stock that needs less additives to fullfill DexosD or Dexos1 gen3 requirement or higher.
  9. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yes, those problems happen because the piston oiling rings get clogged up with sludge/carbon. Changing the viscosity won't help that problem at all. If anything, it might make it a bit worse. The only prevention is more frequent oil changes(6m/5k mile for naturally aspirated and 4m/3k miles for engines with oil-cooled turbochargers or superchargers). And the only solution once it's happened is to either free up the rings or replace them(usually not cost-effective). And if you don't catch it in time and the cylinder walls get scored, your engine block is toast.
    There weren't great solutions for freeing rings non-invasively until Valvoline Restore & Protect hit the market a couple years ago. You can use a powerful engine cleaner(way, way more powerful than the things you can find on the shelf like SeaFoam), but you always run the risk of damaging your gaskets and seals with those aggressive products. VRP seems to help free up the rings over time without doing any damage.
    I'm using Toyota 0W-16 only because VRP doesn't come in that viscosity. The day it does, I'm switching over.
    Tande and Julio_E like this.
  10. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    As for 0W-8 cost, you can get TGMO for as low as $8.28/quart from Toyota dealerships during sales if you shop around. Or you can get Mobil 1 for $28 for a 5qt jug($5.60/quart) from your local Walmart.
    For contrast, 0W-20 Mobil 1 is currently $25 for a 5qt jug at Walmart($5/qt), TGMO would be $2.71/qt at max discount, and VRP is $30 for 5qt at Walmart($6/qt).
    #110 Hammersmith, Jul 26, 2025
    johnHRP likes this.
  11. Trollbait
    12,829
    I asked what brands were using 0w16 besides those from Japan. Not if a consortium has okayed it, nor if car brand what use it in the future.
  12. johnHRP
    646
    189
    KA, DE
    Excel
    ACEA C7 is out 0w16, Some BMW uses 0w16
  13. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't think any BMWs use 0W16, but some use 0W12.
    I'd actually be a little hesitant using it as the only two engines specced for it(recent B48 & B58) are both turbocharged.
    johnHRP and Trollbait like this.
  14. Trollbait
    12,829
    These newer grades were supposedly designed with turbos in mind.
  15. Hammersmith
    2,486
    2,544
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm sure I'd end up using the 0W-12 if the manual said so(I'd just grumble about it first), but I'd absolutely go with a higher quality oil and never go beyond 4m/3k miles. Cooling a turbo is really hard on oils. You can build up a lot of sludge quickly from the heat breaking down the polymer chains. I'm really happy I don't have to deal with that with the Prius.
    (That being said, I also don't agree with all the hate the turbo 4s and turbo 6s get from the V6 and V8 crowds, respectively. I don't buy all this "they're so high strung and they're going to fly apart and fail" crap. Maintain them properly and they'll be fine. But I'm still glad I don't have to do that extra maintenance myself. I'm already dreading my next 6m/5k change because I'm 170 miles away from it and it's 90F/90% around here right now. I'm going to put it off until next week when the temps should be in the high 70s.)
  16. Gokhan
    6,714
    2,672
    Paramount CA
    Having less viscosity-index improver (VII) polymers in the oil helps reduce turbocharger deposits. Moreover, olefin copolymer (OCP) VIIs result in considerably less turbocharger deposits.
    Viscosity-index improvers (VII) / Viscosity modifiers (VM) | Afton Chemical
    Since usually in general, the less is the spread between x and y, the less is the VII content of a SAE xW-y oil, the new thinner oils will have a lot less VII. In fact, it should be possible to make a SAE 0W-8 multigrade oil with no VII at all, effectively being a monograde oil as a result.
  17. Johnny Appleseed
    Johnny Appleseed New Member
    First oil chang, 0w8 in my 2 week old 2026 Prius LE at 750 miles.
    2023p and Gokhan like this.
  18. Gokhan
    6,714
    2,672
    Paramount CA
    Let us know how it works! Did you use the TGMO 0W-8?
  19. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't stray from what the dealer puts in my car.
    johnHRP likes this.
  20. johnHRP
    646
    189
    KA, DE
    Excel
    For Turbo charged car, I won't use thinner than 0w20. Even Toyota recommend 0w20, not 0w16 for their Turbo engines.
    The 0w8 is a special oil that is relatively new. I know that 0w16 has a good early statistical number. Better than earlier cars with 0w20, especially Prius 2010-2014 and 2.5L 2AR-FE 2009-2013 in Camry and RAV4.
    The oil consumption and wear was not caused by the oil but the flaw design of the engines that has tendency to consume engine oil with 10k miles interval. Low tension piston rings:eek:
    The revision to the engine fix this issue and has no problem with 0w16 in the past 10y.
