Chrysler battery-less hybrids announced
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ggood, Jan 19, 2011.
  1. hill
    9,013
    and heavy ... to the point of worthless.
  2. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    So when you PRESSURIZE the water with your thumb...
    Agreed, absolutely.
    But what is the "medium", carrier, of my thumb pressure on the water that results in those air bubbles being compressed, and remain compressed, even though quite distant down in the water from my thumb...?
  3. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    The water IS the medium. Since it cannot decrease in volume when pressure is applied, something else that can decrease in volume will (the air bubbles), since it is a gas that can change volume (PV=nRT).
  4. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    "...Since it cannot decrease in volume.."
    Then how come the bubbles compress, what is the "medium" that carries my thumb pressure through the water to compress the air bubbles.
    Water volume grows with heat, agreed..?
    Then would water volume grow with a decrease in atmospheric pressure..?
    If that is true then wouldn't water volume also decrease with higher atmospheric pressure..?
  5. justlurkin
    499
    63
    Long Island, NY
    No. Liquid water does not change in volume.
    Water molecules will occupy larger volume only if it has been phase-changed to a gas (steam) due to boiling or decrease in atmospheric pressure, or to a solid (ice) when the crystal latticework forms.
    Liquid water is volume-stable. It will not decrease in volume in higher atmospheric pressure.
    And since the volume of liquid water cannot change without a phase change, it makes a good transmitting medium for pressure force.
  6. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Yes, only to add, there is a very slight change in volume when heated, as any other material.
    Properties of water - Wikipedia, the free encyclopedia
  7. telmo744
    2,181
    769
    Portugal
    That should be an incredible "new" approach: power-assisted steering has just began electric, air cond also. If it is to have comfort during shut-off of the main ICE, will the hydraulics feed those systems? Come on, Chrysler, does efficiency and costs improve with this solution? IMHO, no.
    Citroën has done something similar in the ID/DS 50 years ago. Multiple systems working from the same hydraulics and control: suspension, steering and braking. The result: most classic car owners avoid those models.
  8. a_gray_prius
    2,927
    783
    IL
    So.....you should give up the brakes on your Prius? The car doesn't brake using unicorns, lollipops, and puppy sneezes...
  9. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    good luck finding space for it.
    underneath the current minvan, from back to front, its filled by the hiding third row seat, gas tank, then the spare tire.
    somethings gotta go
  10. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    Chrysler should have gone bankrupt....and stayed there....i have a caravan...it hauls what i need moved, but the quality isn't there..
    I have owned cars from gm, ford, chrysler, porsche, austin-healey, nissan,honda, toyota,,, and would rate the chrysler line as lowest of all in quality.... Toyota was a joke when it introduced the toyopet many years ago,,,, honda had the cvcc which looked like a shoe..... But look at them now.....where were the american engineers while the japanese were designing all the good cars we have today:? I think most americans would rather drive american cars if they were comparable with the foreign cars......but that hasn't happened.....most don't remember 1973 when we waited in long lines to get gas.....or the 1940's when we had to use gas stamps to get our quota of gas... You'd think
    our engineers would have learned, but now we owe our souls to the foreign automakers
  11. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    Wow, this is very cool!
    I hope that it works out for them and at an affordable price.
  12. SlowTurd
    1,156
    333
    nj
    compressed air car in france.
    there is a vid somewhere for one from india
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    It actually runs on butterfly farts which are very expensive to gather in useful quantities.
  14. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    Of course not. But the post also mentioned a hydraulic CVT. For that I'm more than happy to stick to my PSD/MG1/MG2 combo. Nothing smoother on the road outside of a pure EV... and without the usual clutches, torque converters, etc.
