Cigarette Lighter not working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Rance, Nov 12, 2018.
  1. Rance
    Rance New Member
    Atlanta,GA
    2014 Prius c
    So I had a inverter that I used in my car that I had before the Prius. I tried plugging it into my Prius and it seems to have done something to the cigarette lighter. Ive checked every single fuse that is located under the driver side area and every fuse is working fine. I used both a fuse tester and for the cigarette fuse I pulled it out and visibly looked at it. Those fuses dont seem to have been blown at all. I then tested the converter in my brothers vehicle and it straight up blew his cigarette lighter fuse. The converter is now in the trash
    Is there another fuse that is not locked under the driver side area that may have blown? Does the cigarette lighter have some sort of internal fuse?
  2. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Next step is to inspect the whole circuit for any signs of damage... Prius have fuse boxes under the dash and under the hood, I'm not familiar enough with Prius C to tell you where to look, but the diagrams on the inside of the fuse box covers will show you the way...
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Under the driver’s side instrument panel
    15 CIG 15 Power outlet
    PriusCamper likes this.
  4. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    That's the only one that I can see. If the fuse isn't blown, maybe your adapter is bad?
    LnG and PriusCamper like this.
  5. Rance
    Rance New Member
    Atlanta,GA
    2014 Prius c
    Yes I checked all these and not a single one was blown.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I would still attempt replacing the fuse, just to see. As I mentioned, from the diagrams, I'm not seeing anything else that is inline between. I'll be following this thread, for sure. Hope it is just a fuse that is "mostly" good, but not good enough?
  7. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    I know it doesn't work unless the car is started.
  8. Rance
    Rance New Member
    Atlanta,GA
    2014 Prius c
    So I finally got around to trying to fix this. Seems when I was checking the fuses for being blown I missed the fact that there was a 20amp fuse where the 15amp should be. So here is a pic of the fuse. I switched it out with a brand new 15amp and the cig adapter is still not working. So at this point I’m assuming the higher amp fuse let too much juice through the line and possibly burnt out the adapter itself. Before all this happened I had replaced the radio so I’m at least familiar with taking those pieces apart.
  9. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Wow... while that fuse looks burnt to a crisp, it's still in one piece. You can pick up an aftermarket adapter pretty cheap at autozone... as long as you don't mind doing the wiring. :D But it sounds like you don't.
  10. Leadfoot J. McCoalroller
    8,293
    7,808
    Pennsylvania
    2018 Prius c
    Many 12v lighter sockets have internal fuses. I don't know for a fact that the c has it, but I commonly see them in Asian cars, so I'd expect to find one in a c.
    Rance likes this.
