Circled yellow exclamation point in parentheses only
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Dadmun, Apr 13, 2022.
Tags:
  1. ChapmanF
    19,055
    That one looks different: a little bitty car on skiddy tracks. The one that looks like ((!)) is the ECB warning light, as described upthread.
    John Dadmun likes this.
  2. John Dadmun
    John Dadmun Junior Member
    52
    New Hampshire, USA
    Well I get that indicator in hard cornering or mud/wet/burnouts. This one is fairly conclusively a brake issue. I haven't yet had the light come back, I think a battery control box of some sort that is by the 12v battery was grounding out, something like that. I suspect it was due to a half gallon of laundry detergent's having spilled on it. Ultimately, I don't know what caused the error, or whether it will return.
    PaulDM likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    When you checked codes with OBD Fusion- did you tick the little box that read "historical codes"? The default setting for that app is off, and it will only pull active codes (ie the warning light is on) unless you tell it otherwise.
  4. John Dadmun
    52
    New Hampshire, USA
    I did not! Great tip, thanks I'll have to check that.
