Circulate air without AC?
Discussion in 'Prime Main Forum (2017-2022)' started by marcoinpb, Mar 3, 2019.
  1. marcoinpb
    marcoinpb Member
    64
    27
    2018 Prius Prime
    Can the fan run and be adjusted without the AC?
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Yes, they’re independent controls.
  3. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    If the ambient temperature is lower than the cabin set temperature, with the fan the heat pump will be activated too, even though the A/C is switched off. And you will notice a slight decrease of the calculated EV range.
  4. marcoinpb
    marcoinpb Member
    64
    27
    2018 Prius Prime
    I indeed, but the decrease of the calculated EV range is decreased 10-15%. Simply want to run the fan without heat pump AC.
    Thank you.
  5. bisco
    52,693
    set the temp to 'low'
    set the air to fresh or recirc
    set the air direction
    set the fan to desired speed.
    ignore the reduction in estimated ev miles, it's a dumb indicator letting you know that using hvac can reduce your ev range.
    it should only activate with cooling or heat, but toyota chose to fan activate it for some strange reason
  6. marcoinpb
    marcoinpb Member
    64
    27
    2018 Prius Prime
    A dumb question: “set the temp to “low” “. Won’t that turn the AC on when all I’m trying to do is circulate outside air in the car?
    Thank you for any help.
  7. mr88cet
    2,313
    1,335
    Austin, TX
    If the A/C is Off, then it won’t kick in. So temperature = Low and A/C = Off, essentially means climate-control other than whatever you set for the fan to do.
    bisco and Pdog808 like this.
  8. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    @mr88cet is correct. He is saying you need to set your A/C temperature to below 60 degrees - where the indicator says "LO". This should keep your heater from kicking on even though the outside temp may be, say, 50 degrees.When the heater used to go on even though I had my entire climate system set to OFF, my battery percentage indicator would drop like a rock.
    BTW, I ALWAYS use the battery percentage indicator and not the estimated battery mileage indicator. That way you will know EXACTLY when you hit zero and the engine will start up.The battery mileage indicator is little better than a SWAG.
    FuelMiser and bisco like this.
  9. bisco
    52,693
    just make sure the light is off on the a/c button
    Pdog808 likes this.
