city mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PapaSB, Oct 15, 2012.
  1. PapaSB
    PapaSB Junior Member
    40
    UK
    has anyone else got a view or experience on of city mode gives less torque than ev mode.
    Those morning I forgot to turn it on an it felt like there was more pull going up hill...
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    City mode? Where are you located?
  3. PapaSB
    40
    UK
  4. cwerdna
    12,545
    2,125
    SF Bay Area, CA
  5. PapaSB
    40
    UK
    OK. Might be the throttle response, however, i suspect its another layer on top of the ECO button as well - thus making the battery last that little bit longer - probably by reducing the watts (?) to the motor and therefore reducing torque
    I use CITY MODE a lot, and never take it out of ECO or really put it into HV mode unless the battery is depleated.
    On the motorway (freeway) the City Mode works fine as it allows electric up to 62 mph and won't turn on the ICE.
  6. bisco
    52,774
    interesting. i wonder why we don't get that? we're not all leadfoots!:p
  7. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I don't personally know, but Googling for congestion charge uk "ev city" might be insightful.
  8. lensovet
    2,615
    496
    Burlington, NJ
    because we get power mode and all of our engines in regular cars come in larger sizes (corolla, yaris, etc)
  9. bisco
    52,774
    because we're americans! and we have a right to more power!:rolleyes:
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    From what I have read "city mode" means that the ICE won't come on unless you really floor the throttle. Apparently there are "zero emission" zones in some European cities, and city mode helps insure that you won't inadvertently violate the restriction. As far as I know, we don't have anything like that in the U.S. or Canada.
    BTW, "Power" mode in the U.S. doesn't increase the available power. It just changes the power curve on the throttle (distance pushed vs. commanded power) to make it feel peppier. Floor it in either ECO or POWER mode, and you get the same power (from the combined ICE and electric motor).
    lensovet likes this.
  11. Adam Leibovitch
    498
    102
    Ahhhh....Maybe thats whats happening with me. Sometimes in eco mode, going at a slight upward grade, I push the gas and hear the engine picking up but really no acceleration, almost like when you try to switch into 3rd gear on a manny but accidentally hit 5th and get no throttle response.
