Clamp removal- air intake
Discussion in 'Gen 2 Prius Technical Discussion' started by tugga, Apr 12, 2022.
  1. tugga
    tugga Junior Member
    Mississauga, ON
    Hi everyone,
    I am trying to use a Philips head to loosen this clamp so I can move the air intake out of the way as I plan to change the serpentine belt. I am stuck and can’t even remove this clamp. Sprayed wd40, waited but still not able to Loosen it. Any ideas to help?
    Thanks
  2. ChapmanF
    19,063
    You'll probably get better purchase on it with a 10 mm hex socket.
    It might just break anyway if it's that rusty. But there probably won't be a problem putting that snorkel back on unclamped and driving as far as the dealer for a new clamp.
  3. tugga
    tugga Junior Member
    Mississauga, ON
    So try removing it with a hex socket?
  4. ChapmanF
    19,063
    Yes. You'll see it has a hex head, that just happens to also have Phillips screwdriver slotting in it.
  5. tugga
    tugga Junior Member
    Mississauga, ON
    Perfect. Thanks a bunch. This worked.
  6. tugga
    tugga Junior Member
    Mississauga, ON
    Thé struggle now is after loosening the tensioner pulley bolt, I even took it out, the serpentine belt does not come off. Am I doing something wrong? See pic. 16364EB5-6C5E-43E2-A267-7177F3FDFD0F.jpeg
  7. ChapmanF
    19,063
    Did you loosen the bolt that goes through the center of the pulley?
    That has to be loosened also (and it can be a bear).
    The one you took out is only an aid for setting the proper tension of the new belt. You start with it loose, put the new belt on, then gently tighten that long bolt until the belt tension measures at the spec in the manual. Then you tighten the pulley center bolt to its specified torque.
  8. tugga
    tugga Junior Member
    Mississauga, ON
    Yes, I did loosen the bolt that goes through the Center of the pulley first and then the tensioner bolt that was so hard to loosen. I did and took it out. Nothing happened to the pulley. It has to slide off so I can take off the serpentine belt but couldn’t. Don’t Know why this is happening.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    iirc, because I may have this mixed up with another car:
    Step one is loosen the center bolt on the pulley to remove the clamping force.
    The tension adjusting bolt passes through that (unthreaded) hole in the photo and then threads into a slide mechanism. You turn the bolt clockwise and it pulls the pulley toward the front of the car, tightening the belt. You turn the bolt counterclockwise and the tension on the belt will pull the slide mechanism toward the back of the car, loosening the belt. Sounds like the slide mechanism is seized. perhaps spray some wd40 into the area in the hole, insert the bolt, thread it most of the way in and use some mechanical agitation (ie: a hammer or similar device) to thump the bolt to try to push the slide mechanism.
  10. tugga
    tugga Junior Member
    Mississauga, ON
    That’s what it looks like. It is strong like a rock now. I’ll spray some wd40 and see if that helps. No other easy way to access the bolt with a hammer to give it a slight blow as working space is tight. Do I have to remove the wheel to get better access?
  11. ChapmanF
    19,063
    In your photo, am I seeing the center bolt through that idler pulley? Maybe my eyes are playing tricks on me. I can see that the long bolt for tension adjustment is removed.
    Are you thinking of 'agitating' via the center bolt, or via the long adjusting bolt? I think you might have success with either approach. The long bolt might allow easier access, you'd just bop down on its head from the top.
    This sounds like the kind of thing I'd pull out the air hammer for. Dialed down, or just squeezing the trigger gently. It's really not how hard the bops, but how many. Air hammer can deliver a couple thousand in a minute's time; I can't do that with a hammer.
  12. tugga
    tugga Junior Member
    Mississauga, ON
    You are right. The long bolt for tension adjustment is removed. I don’t have an air hammer so any other ideas to knock that off. I guess the serpentine belt area wasn’t touched since 2008 and the car has seen so many winters here in Ontario and after nearing almost 300,000kms I said let’s change it and it took over 4 hours for me to loosen these bolts. First timer working -
    Could be because of that and then you run into not being able to get the belt off after all these. Fun I’d say.
  13. ChapmanF
    19,063
    I still think I would put the long bolt back in, just for several threads, and use it as a thing to bang on.
    If not with an air hammer, then long and exhaustingly with a regular hammer.
    Or call in a favor from a friend with an air hammer.
    Or buy a new engine mount bracket and idler pulley and use the old stuck-together ones as a centerpiece.
    Seriously, if the idler pulley is that old, its bearing might be a week away from getting noisy, if it hasn't already.
  14. Mendel Leisk
    42,383
    Some repair manual info on drive belt replacement:
  15. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    Commit to replacing whatever is needed. Remove the tensioner pulley center bolt completely. Pry, tap, hammer, work it, - just get the pulley off. Remove the bracket (and water pump pulley) as needed. If possible, I like to work on something rusted up "out in the open" - on the bench.
  16. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    Note that that procedure contains an error in both the removal step 3 and install step 2. The parts labeling is transposed in each case. The part labeled 'A' should be 'B' and vice versa. The illustration below shows the correct labeling.
    Of course, it will eventually be worked out*, but if you have a procedure, you should be able to rely on it.
    * more quickly for the experienced; more slowly for those that rely on correct procedures
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    #17 edthefox5, May 21, 2022
  18. ChapmanF
    19,063
    Notice that what you've written here matches the drawing the way dolj corrected it in #16, and not the way it is shown in the manual.
