Clarification on P0A93 Inverter Cooling Pump issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JustaMom, Aug 16, 2012.
  1. JustaMom
    JustaMom New Member
    Hello All: I recently purchased a pre-owned 2008 Prius with 55K miles on it. I'm hoping some experts could clarify the P0A93 code. My dash lit up with the Master warning light, malfunction indicator lamp and then the hybrid system warning light. I drove straight home only a couple of miles. It was really hot outside and the air conditioner stopped blowing cool air, I immediately turned that off. I didn't even drive it to the dealer, I had it towed even though it seemed drivable. Before I had it taken there, I checked the plastic reservoir container to check for fluid movement, the reservoir was full and moving when I turned on the car. --- The dealer called me to tell me I had the P0A93 code and I needed to replace the inverter cooling pump. Is this correct as my fluid was moving around? It seems that every other year has been covered by a special recall for this pump, and why not the 2008s, am I the only 2008 owner with this issue? Thanks for your help.
  2. Patrick Wong
    18,210
    6,515
    You are not the only 2008 owner with this issue.
    Perhaps the pump was not operating with a normal flow rate. For now, I would assume the dealer tech has correctly diagnosed the problem (the Toyota dealers certainly have plenty of experience with Prius inverters overheating for this reason).
    I suggest that you authorize the repair, pay the bill, then write to the Toyota Customer Experience Center, provide a copy of your repair invoice, cite the LSC which covered earlier 2G models (do a search on PriusChat for details), and ask for a refund of your payment.
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    We seem to be hearing more and more inverter coolant pump failures on 2008/2009 gen2's. It is becoming increasingly obvious that these later vehicles should be included in the LSC up to 2007. I have a 2008 myself at 84,000 miles and feel it only a matter of time before the pump on my vehicle fails.
    Come on Toyota if you wan't to keep customers include all gen2's.
  4. JustaMom
    JustaMom New Member
    Update: The dealer called to tell me that I have an extended warranty ! (it apparently came with the car when I purchased it, previous owner must have purchased it), good until next Jan or 100K. They replaced the pump under this warranty. Still... 2008 & 09 should be included...I just got lucky with this warranty. Now they are asking me if I would like to replace my belt as it is 4 years old. No visible wear. Just that it's 4 years old. hmm.
  5. Britprius
    5,194
    1,922
    Glad to hear it did not cost you anything and the dealer did inform you of the extended warranty.
    I feel this issue is going to come back and bite Toyota as if the new pumps are already installed in 2008/9 vehicles they are proving to be just as unreliable as the old pump.
  6. Britprius
    5,194
    1,922
    As a matter of interest what pump is fitted to the 2010 gen3 vehicles, and is it possible or reasonable to fit that pump. Have gen3's had pump failures in any quantity.
  7. Patrick Wong
    18,210
    6,515
    I would say that the serpentine belt should be replaced next year as a preventive maintenance measure, after you've logged 60K+ miles and the belt is five years old. At that point, when the belt is removed, there will be plenty of cracks visible on the inner surface; while the outer surface will be shiny due to minor slipping against the engine coolant pump pulley which contacts the outer surface of the belt.
  8. Patrick Wong
    18,210
    6,515
    You'll need to monitor the G3 forums, but my prediction is that as those vehicles age, you will see more than a handful of owners reporting failure of not just the inverter coolant pump but also the engine coolant pump. The latter of course will be a more significant failure.
  9. JustaMom
    JustaMom New Member
    So will my engine coolant pump also fail? Should that be replaced as a preventive service when I reach a certain mile-stone...ha ! I made a funny,,, I can say that now that I didn't have to pay for the inverter pump, but not so funny for all of the o8s & 09s that should be covered. The gent who "writes up" the work order said that warranty saved me about $800! Not right for all the 08 & 09s that fail. Ban together prius people.
  10. Patrick Wong
    18,210
    6,515
    While the 2G engine coolant pump eventually will fail, you don't have to worry about replacing it as a preventive measure. It will give plenty of warning before it fails.
    The typical failure mode of a mechanical coolant pump is a leaking shaft bearing. This can be seen (if you look) as a pinkish stain on the inside of the coolant pump pulley and on the top of the air conditioner compressor housing below the coolant pump. The coolant reservoir mounted behind the radiator will also show a drop in coolant level. In extremely leaky situations, enough fluid leaks so that a stain is thrown up on the underside of the hood.
    On the other hand, the problem with electric engine coolant pumps (such as is found in 3G Prius) is that the typical failure mode is the motor seizing up. Hence there is no warning. One day the pump is working fine, the next it is totally dead and whatever was supposed to be cooled by that system will overheat.
  11. Bobby McCallister
    Bobby McCallister New Member
    Benton, Arkansas
    Even if you have a 2007 that is included in the recall, just hope and pray that the VIN is included. My 2007 Prius check engine light came on last Sunday. The vehicle only has 49,000 miles on it and is less than 2 months outside of warranty. Toyota "graciously" has comped the pump, but I am having to pay for the repair for them putting a knowingly defective part in this vehicle. I guess their accountants told them what VIN's they would have to cut off of the recall in order to maximize profit.
  12. miguelzottoyahoocom
    miguelzottoyahoocom New Member
    Mexico City
    Please help me out i have a prius 2004 in which runs good no problem on it, recently around 3 months i replace the P0A93 code the inverter pump the electric one in the fender with a new dealer one and 6 months earlier i replace the other pump down the fuse box the car. my car runs well but after all day using it long tris around town the vsc lights and red triangle lights up, i scan the car and no codes on it, then next day still the same and after driving it a little lights get off if i drive the car in short trips no problem but then after driving long ones lights come on again, then also get the car scan and the code P0A93 return but the part already replace recently, also i try to purge the system but the same problem can someone help me out on getting this solve????
  13. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Caroline at Luscious Garage reports that the invertor pumps on the Gen 3's are just as susceptible to failure as they are in the Gen 2's.
    Miguel what type of scanner are you using to retrieve your DTC's. If its not a compatible scanner for the Prius you may not be doing yourself enough good. If the VSC and red triangle lights are illuminated then one or more DTC's are logged in the ECUs. Get those codes and report back. Are you confident you were able to successfully purge the are air out of both cooling systems when both pumps were replaced?
