Classic Prius 2002 won't run
Discussion in 'Gen 2 Prius Technical Discussion' started by pigwot, Oct 26, 2007.
  1. patsparks
    10,664
    567
    Adelaide South Australia
    I guess working for a wage wasn't so bad. I really wouldn't give the mechanics too much of a hard time, if you do they might realise they can make much more money in other fields like I did. :D
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(patsparks @ Nov 3 2007, 11:58 AM) [snapback]534302[/snapback]</div>
    flat rate is ridiculous. we can't wait to have a reliable income that doesn't drop to near zero during the months of january, february and march.
    it also promotes shortcuts and upselling of major service jobs, which of course are all good for the dealer's pocketbook.
    DH's favorite customers were the ones that insisted upon overmaintaining their cars. well those and the ones that undermaintained to the point where he had to do major work to restore their car. but his favorite part of the job, diagnostics? never, ever was enough to pay the bills.
  3. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    While this one really sounds like stuck throttle plate, it's also
    easy enough to hang a probe off the fuel pump power lead and *see*
    if it's getting power or not. This is basic basics that you'd apply
    to any car, and they shouldn't be using the "prius excuse" for not
    going through these fundamental steps.
    _H*
  4. pigwot
    pigwot Junior Member
    <div class='quotetop'>QUOTE(Bear68 @ Nov 3 2007, 07:08 AM) [snapback]534266[/snapback]</div>
    You have a good point there, I will be speaking to them early tomorrow and ask them if they have checked that circuit opening relay. And I will Bear68 (pun intended) in mind what you and Galaxee have said and try to control my rancor... ...I should know better as a friend used to be a service writer at the same dealership!
    Thanks again for all the advice.
  5. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Well, someone once said "You get more flies with honey than with vinegar."
    Seems like a good idea,
    If you like flies...... :lol:
  6. pigwot
    Well, the car is back; Codes reported were:
    P1390-P1391-P3101-C1259 (not P3190, P3191).
    They replaced the ECM; Removed, cleaned and replaced the intake manifold, and charged the HV battery pack. They note that it "Smells like it is running on old gas / from exhaust & fuel cap"
    That is very odd as we purchase gas from a very high volume 24 hour Sunoco station near our home.
    They stated it was not covered under the 100k / 5yr extended warranty.
    All told they charged $321.30 for their time.
  7. wile-e
    wile-e Junior Member
    50
    Check with the gas station and see if they had any problems with a mix of diesel in the gas. That 'old gas' smell sounds suspiciously like diesel was the culprit.
