Classic Prius Coolant Replacement
Discussion in 'Generation 1 Prius Discussion' started by BentSpace, Jun 27, 2011.
  1. Patrick Wong
    18,210
    6,515
    I no longer have my 2001 repair manual as I got rid of it when I sold my 2001. The repair manual probably has similar instructions as 2G. If you want to verify, you can subscribe to techinfo.toyota.com so that you can download repair manual pages for your model year.
    I believe that the correct practice is to open both bleed valves at the same time.
  2. BentSpace
    BentSpace Member
    195
    Reno
    Well, still at it. I drive it around my property which include a steep hill and bumps and weird angles and that seems to help because right after I do that lots of air comes out the first couple bleeding trials but then no air come out for like 3 trials and I take it for another spin and presto more air comes out. Will this ever end? The only problem is I have to wait till it cools off before I open it cause your not supposed to open it hot, but what would happen it I did? How cool does it have to be before you can open it? Like waiting till the low coolant temperature light comes back on cool?
  3. Patrick Wong
    18,210
    6,515
    I would just feel the outside of the coolant reservoir, and if it is not very hot then it would be OK to slowly open the cap.
  4. BentSpace
    BentSpace Member
    195
    Reno
    Wow, you weren't kidding, this is definitely a PITA. I still keep getting air out every time I drive to the bottom of my hill and back up. I'm not hurting the inverter am I by keep driving up and down?
    Seems like the only way I get get the air out.
    I've been working on this since yesterday afternoon, have you ever hear of it taking this long?
    Maybe there is something wrong with my system or I'm doing it wrong?
  5. Patrick Wong
    18,210
    6,515
    I changed the inverter coolant 2x when I owned my 2001. I also recall that it was a PITA to do it, but I did not have to drive around in order to get the air out. However I suggested that process because I know it worked for some other owners.
    It appears that it is helping for you to have the car pointing up and down. Maybe you don't have to drive to the very bottom of your hill and back.
    Regarding potential damage to your inverter, if your total drive is 1 mile or less then I don't think you need worry.
    I hope that you listened to the sound of the inverter pump before you started this process. When you hear that particular sound restored, and you can see fluid turbulence in the reservoir, then you can declare victory.
  6. BentSpace
    BentSpace Member
    195
    Reno
    Yes, I did listen to the sound before hand and the turbulence seems to be completely restored. The sound of the water pump though I'm not so sure on now, I remember it being more of a constant hum, right?
    Now it's not loud like when you first change it, but I can hear a non constant squirting sound which I believe is air in there. Also the fact that every time I drive to the bottom of the hill and back more air comes out and it seems to be quite of a bit of air too has me thinking there still air in there. As long as air keeps coming out, I'm not done, right?
  7. BentSpace
    BentSpace Member
    195
    Reno
    Will the inverter throw a error light to let you know it's overheating before it destroys itself?
    There's no way that I'm getting new air in the system somehow, is there?
    As long as air keeps coming out, I have to keep bleeding, right?
  8. Patrick Wong
    18,210
    6,515
    The water pump should sound like an aquarium pump and you should not hear air bubbling around in the system.
    Is it possible that air is leaking where the hoses are connected to the bleed valves, or that the bleed valves themselves are letting in air when you open them up?
    If you see fluid turbulence then that is a good sign that the pump is working properly. I would be inclined to declare victory now.
    If the inverter is overheating, then the hybrid vehicle icon should appear before the inverter blows up, but there is no guarantee about that.
  9. BentSpace
    BentSpace Member
    195
    Reno
    I suppose that's a possibility, I always seems to have problems bleeding anything, brakes, etc. Though why would it only happen right after driving it.
    I certainly hope so. Though I'm still a little concerned that air keep coming out when I bleed it right after driving and the sound the pump is making.
    I made a video to show you what's happening with the air coming out right after driving it. It's kinda hard to hear the squirting sound the pump is making so I made a separate recording of that where you can hear the sound it's making.
    I made this recording with the mic close to the driver side of the inverter where I believe the water pump, right?
    [ame="http://www.zshare.net/download/92304475bd956591/"]Sound of Inverter Water Pump.m4a - 2.23MB[/ame]
    In the recording you can hear 3 distinct sounds, the gurgling in the reservoir tank, a faint constant hum, and an irregular squirting sound, which is the one that's got me worried it might be air. Is that the sound of air in the system or is that the normal sound?
    Really wish I would have made a before recording to compare it to.
  10. Patrick Wong
    18,210
    6,515
    As long as the inverter coolant reservoir shows the turbulence and the front of the reservoir has a higher level compared to the remainder of the reservoir, you should be good to go. I'm not sure about the source of the irregular squirting sound or whether this might imply the pump is getting flaky.
    If there was air in the system you should be able to hear air bubbling instead of the steady hum made by the pump.
    In the future, I would suggest using the minimum tubing length required to connect the bleed valves with the reservoir opening. I don't think it helps to have that excessive length of tubing which results in more required force to push fluid up to the opening.
  11. BentSpace
    BentSpace Member
    195
    Reno
    Wow, that's great.
    So, it's safe to drive?
    If there is any air left in the system, will it purge itself eventually?
    So, you didn't hear any bubbles in there?
    So what do you think is up with the air coming out after driving it?
  12. Patrick Wong
    18,210
    6,515
    I did not hear bubbling while the pump was running. Since your pump is providing good circulation, any remaining air bubbles should flow through the system and end up at the reservoir where they will go away.
    Possibly, air is entering the system at the bleed valve, when it is rotated counterclockwise to open.
  13. BentSpace
    BentSpace Member
    195
    Reno
    Yes, you may be right, as it usually happens when I open the bleeder quite a bit. How much are you suppose to open bleeders?
    Also after drive and fluid warms up, is probably somewhat expanded and when I open the valve the excess pressure might be coming out
  14. BentSpace
    BentSpace Member
    195
    Reno
    I always have the hardest time with bleeding things, how do you tell the real air bubbles from ones coming from the valve?
  15. Patrick Wong
    18,210
    6,515
    I usually will open the bleed valve the minimum amount needed to get a reasonable flow. I agree that it is not easy to tell whether air remains in the system or if the air is entering via a leak between the bleed valve and the housing that it screws into.
  16. BentSpace
    BentSpace Member
    195
    Reno
    Yeah, they definitely need to design a better bleeder valve. There still using the same crappy design from forever ago.
  17. BentSpace
    BentSpace Member
    195
    Reno
    I took a look at the 2002 repair manual, trying to download the whole thing right now, and it's says basically the same thing as the '04 and '06 manual, you just open and close both of them together.
    Would it cause a problem if I accidentally turned the key on with the bleeders valves open?
    In my delirium of the endless bleeding, 1 time I turned on the key with the bleeders open and it started sucking fluid out of the reservoir through 1 bleeder hose and coming out of the other bleeder hose.
    Also another thing I think I didn't do, was initially after draining the coolant, the first thing you're supposed to do is add coolant to the reservoir till the fluid level in your bleeder hoses reaches the full mark on the reservoir, which means you have to overfill the reservoir to get it to that level. That's not a problem, is it?
  18. Patrick Wong
    18,210
    6,515
    There is no problem as long as you see fluid turbulence in the reservoir when you are done.
  19. BentSpace
    BentSpace Member
    195
    Reno
    Awesome, well it would seem that I am done and I just wanted to send the biggest thanks and gratitude your way for all your help, Patrick. You must have great karma, you are definitely a life saver.
  20. BentSpace
    BentSpace Member
    195
    Reno
    One interesting thing I observed is after driving it, whether just down the hill or across town, afterwards the coolant level is significantly higher then before I left. However, when I bleed it right after driving and all that air comes out, the coolant level in the reservoir drops back down to where it was before driving. Which is interesting because if the air was coming from the bleeder valve itself than you wouldn't expect the fluid in the reservoir to drop. Given the manual doesn't say anything about bleeding after driving, so maybe it's possible that air gets into the system from driving, is that normal?
