clatter/shaking, CEL on, oil on 2 plugs & coils... diagnosis?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sukatoro, Feb 3, 2018.
  1. sukatoro
    sukatoro Junior Member
    37
    Houston Tx
    OK... spent yesterday changing valve cover gasket, cleaned EGR up to the valve but couldn't get it or the cooler off, have changed plugs but only moved coils around, no replacements on hand as of yet... started it up today to be greeted by the same awful clatter. as much as it pained me to do so, let it idle long enough to check codes on mini-VCI, and omg here goes the new, improved list...
    P0102 mass air flow circuit low
    00108 manifold absolute pressure circuit high input
    P0113 intake air temp circuit high input
    P0123 throttle pedal position sensor switch A high input
    P0300 random misfire
    P0301 misfire 1
    P0302 misfire 2
    P0304 misfire 4
    P0352 ignition coil B primary/secondary circuit
    P0403 EGR circuit
    P2135 throttle pedal position sensor/switch A/B voltage correlation
    w.t.f.
    keeping in mind when this started I only showed p0300, p0301, p0304... what's next step? is my engine shot? is there no point replacing all coils today? could bad gas or ex-gf sabotage give results like this,?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    the egr cooler cleaning is necessary,after that make sure all connectors and hoses are securely attached
    m.wynn, Raytheeagle and mjoo like this.
  3. danlatu
    danlatu Senior Member
    533
    1,363
    maryland
    Take out your intake plenum and egr system and clean it. Spark plugs getting loose will cause the coils to get fouled with oil like the pics you posted. Use anti-sieze on your new spark plugs and torque them to spec. Engine knock is from detonation = too much compression. You have oil getting sucked into the intake manifold from the pcv valve and being burned in the combustion chamber. That is why your map sensor is covered in oil. After you clean the intake plenum and egr system, install an oil catch can. Problems will not come back. I know during the cold months, members like to open new threads regarding this knock problem. If anyone has wet oil in the intake plenum, get an oil catch can. Wet oil does not come from the egr system, it comes from the pcv valve. If you are experiencing this knock at start up, it will eventually blow the head gasket.
    map sensor look like this?
  4. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I agree. Before doing any of the cleaning work, I would buy an inspection cam and check each cylinder after the engine has sat overnight. If there are any signs of coolant, then it would explain your misfires.
    Headgasket issues are not uncommon with these engines as they get older and unfortunately, you cannot rule it out as a possibility.
    m.wynn and Raytheeagle like this.
  5. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Doesn't sound too bad. But to be 100% sure - is there an oily milkshake in the reservoir?
    Pixel XL ?
  6. sukatoro
    37
    Houston Tx
    the coolant reservoir? the coolant inside is still its usual pink color, it doesn't look oily from viewing the coolant resevoir from my usual viewpoint, should I get some of the coolant out to check closer?
  7. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Sure, If that helps
    Those Confederate engines have an easy life without the cold starting.
    Pixel XL ?
  8. sukatoro
    37
    Houston Tx
    hi all, OK... been a while but have spent much of my spare time trying to get this poor car going again, here's a list of what's been done/replaced up till now, and a current description of the issue..:
    replaced plugs
    replaced coils
    replaced PCV valve
    cleaned EGR circuit (pipe, intake, valve, cooler)
    replaced intake manifold gasket
    replaced valve cover gasket & plug grommets
    changed oil and filter
    OK, so when I got the EGR cooler off finally I found it to be literally sealed off it was so clogged, you couldn't even blow through it... took 4 days of soaking and use of a gas-powered pressure washer to get it cleared... capillaries of intake manifold were very gummed up too. yesterday got the coolant refilled properly and air bled, and fired it up... MIL is gone, idled for 6 minutes sounding normal, then here we go... clatter, knock, bang bang bang. P0303 shows up on techstream three times, have to shut down as it sounds like it's chewing itself to pieces.
    still, no coolant loss at all, and oil looks normal, no smoke from exhaust whatsoever, although I have noticed when uncapping coolant reservoir there is a tiny amount of pressure released when I twist the cap... does this put me in blown head gasket territory for sure then? last night when I tried letting it idle the misfiring got bad enough that the car was shaking violently.
    whats my next move, is there anything else left to check before getting internal with the engine? could filthy/fouled injectors cause this awful misfiring issue?
    lastly, I noticed in my teardown that the inverter coolant seems still and unmoving, unless this whole "turbulence" effect is something so subtle it is high undetectable...
    any advice friends? I really don't want to junk the car, but I don't want to beat my head against it or throw good money after bad... I'm willing to try the head gasket myself, am just worried about something being messed up in the bottom end too. thanks in advance all, any pointers would be great, if anyone thinks pulling the injectors to clean would be worthwhile let me know!
  9. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Check/clean your sensors: MAP, MAF, O2. At that mileage I'd suspect a bad O2 sensor. Then with the car warmed up unplug one sensor at a time and see which unplugged sensor removes the misfire? Check fuel pressure.
    Pixel XL ?
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You could also try moving the coil around and see if the misfire follows.
    sukatoro, m.wynn and mjoo like this.
  11. Mendel Leisk
    41,328
    First time I removed the cap on our engine coolant reservoir I also heard a slight phttt sound, no engine problem here. That's not to say you don't have a problem, but I believe it's normal to have a slight pressure build-up.
    Raytheeagle likes this.
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Slight pressure is normal ;).
    As the coolant warms, some will convert to gas, increasing pressure in the loop.
    If the coolant color is not pink or the level declines, that’s not normal ;).
    m.wynn and Mendel Leisk like this.
  13. padroo
    padroo Senior Member
    2,763
    2,252
    Before you go pulling the head off the car you need to do a "Cylinder Leak Down Test", that will tell you the internal health of the engine and also help diagnose if there is a problem. You can buy the tool at Harbor Freight .
    http://www.harborfreight.com/cylinder-leak-down-tester-62595.html
    Once you know the engine internals are good or bad then you can proceed to other troubleshooting.
    mjoo and Mendel Leisk like this.
  14. sukatoro
    37
    Houston Tx
    thanks to you all for the replies... just spent a fruitless evening poking at the car again, dpuble-checking what I could, result has been same as before; fires up and sounds normal, for about 15 minutes this time. I watched the live data from Techstream during this time, that is where I saw the cylinder 3 misfires again.
    I tried swapping coils & plugs between cylinders 2 and 3 last night, the misfire does not follow coil/plug, although tonight I did see a misfire register from cylinder 1 (the first actually, but only once), all subsequent, and progressively violent misfires were at cylinder 3). once they really start getting bad I feel I have to shut the car down, they are very loud and somewhat rock the car... I honestly don't know if the effects are coming from the engine, or the dampening plate w/ all the springs on the transaxle slamming about due to the engine motion, it sounds loudest from beneath the car on the drivers side I think.
    my coolant level is not going down, nor has the color of the coolant changed...
    I also noticed tonight, while trying to determine if water pumps were working or not (still not sure about these!) I noticed a sound I've gotten used to hearing under the hood when ICE is off and car is in ready... it sounds EXACTLY like the 1st-gen in this video..:
    I tried to determine where it was originating from, and I'd swear it was coming from either the throttle body or somehow (?) within the intake manifold itself... the much older Prius in the above video sounds exactly the same, although no explanation was put forth there unfortunately.
    I will! see if I can get ahold of the referenced tool from harbor freight today, many thanks for that pointer padroo. I have read so much here on the fora I am sti!l clueless to decode my symptoms.
    I can add that tonight when the misfiring started up again my coolant temp was only at 140f... the only other thing I could add is that I think most everytime the cacophony ensues the ICE engine is trying to charge the HV battery, which has two weak blocks apparently (7 & 10), but only rarely throws a PA080... I still don't honestly believe the inverter coolant is turbulent or swirling, I see no motion personally but have read it can be hard to perceive... tonight no MIL appeared despite the spate of misfires, it I'm sure if it'd taken it out on the road I would have racked up some P0303, P0301, etc... the again everyone!
  15. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    One option close to you if you feel you’ve done everything you can is to visit hometown hybrids as they might be able to help. Maybe try calling them when they are open and see what they have to say.
    How long have the spark plugs been in there? How bad did the last ones look?
  16. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Thinking about what breaks down at that mileage that could cause a misfire... Partially plugged/leaking injector, sensors (lean condition), low fuel pressure. Can low compression cause a misfire?
    Mouse snacking on a wire harness?
    Pixel XL ?
    #36 mjoo, Mar 11, 2018
    m.wynn, Raytheeagle and Mendel Leisk like this.
  17. sukatoro
    37
    Houston Tx
    it was idling nice and normal for a good while (20-30 mins) so i took it around the block tonight with Techstream up and running, hadn't made it a block before the misfiring started up again, first with one misfire at cylinder 1 and then thirteen consecutive misfires at cylinder 3... always seems to be at 3, its not just like the engine is missing, it is violent and loud.
    going to try to make it to harbour freight today for the leakdown test kit, hopefully that will enlighten... car is starting to get dusty.
    any tips or suggestions as to other things that could cause these misfires would be greatly appreciated, thanks all.
  18. Patrick Wong
    18,200
    6,500
    Why not replace the fuel injector for cylinder 3.
    mjoo likes this.
  19. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    mjoo likes this.
