clatter/shaking, CEL on, oil on 2 plugs & coils... diagnosis?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sukatoro, Feb 3, 2018.
  1. sukatoro
    sukatoro Junior Member
    37
    Houston Tx
    borrowing an air compressor to perform a leakdown test tonight, hopefully i can figure out how to rotate the engine into position (pistons up/down), currently all four of them are at the same level... also going to pull injectors finally to at least visibly inspect.
    there's something that's really bothering me at this point though, and it's this... when i finally made it back to the EGR cooler i found it TOTALLY sealed with carbon, as is no flow whatsoever... so how come i wasn't ever getting codes relating to EGR flow thrown, ever? even more troubling, i cleaned the entire egr circuit spotless, and the car doesn't sound any different at all now that its clear... I've read many reports of smoother engine sound but no difference at all in my case. I'm beginning to think my exhaust is clogged further downstream, at the first cat perhaps?
    can anyone comment on the weird sound near my throttle body or i take? It is identical to the car in video i posted above. i did notice that when in park my throttle response seems delayed, i can press in the accelerator pedal and there is a noticeable delay in response before the engine spools, does this behavior denote anything to anyone?
  2. sukatoro
    37
    Houston Tx
    completed cylinder leakdown test tonight, compression is good in all cylinders... even cylinder 3!
    what's next, I am thinking injectors, toying with ordering a set of 4 remanufactured Denso injectors from Rock, and going to start tearing into exhaust from manifold to back of car, not going to be surprised to find first cat in rough shape.
    can anyone who has done exhaust comment on what parts I am sure to need when reassembling? I know some of it will break in the process or removal; hangers, washers, etc.?
    if anyone can add to my list of things to do/check, please interject and the to all for your help..!
  3. mjoo
    mjoo Senior Member
    1,149
    1,326
    Michigan
    Bad gas? Fuel pump not providing enough pressure? I hear that the FP is easy to replace.
    Pixel XL ?
  4. mjoo
    mjoo Senior Member
    1,149
    1,326
    Michigan
    Did you do this?
    Pixel XL ?
  5. mjoo
    mjoo Senior Member
    1,149
    1,326
    Michigan
    Some EGR codes require a working MAP sensor. Did you CLEAN it and intake manifold?
    Pixel XL ?
  6. padroo
    padroo Senior Member
    2,763
    2,252
    mjoo likes this.
  7. sukatoro
    37
    Houston Tx
    hi all, OK sorry for the extended delay friends but I had to walk away from her for a bit, just too frustrating to try to diagnose at this point... trying to muster the will take start taking it apart, again.
    last weekend I finally got my fuel injectors replaced, with remanufactured OEM Denso's from rockauto and put it all back together, painstakingly after having to remove the EGR circuit to get at the furl rail safely, started her up,it coughed a little, caught, leveled out and idled fine for about 8 minutes... and then started misfiring and slamming just like before, eventually becoming so violent the car must be turned off as it sounds like its coming apart at the seams. damn. I also noticed as the car began misfiring in earnest a very small rivulet of grey looking water was dripping somewhat steadily from my tailpipe... never seen anything like that before.
    after cleaning the entire EGR circuit to spotless, I have so far replaced coils, plugs, injectors, PCV valve, intake gaskets, valve cover gaskets, performed cylinder leakdown test, and spent countless hours disassembling and reassembling the car... invariably, the car will idle fine until the ICE is called upon to recharge the HV battery; once it comes time to recharge, the misfiring begins again in earnest, and soon reaches a point where it must be shutdown... I don't know what this means though... can other parts of the hybrid system (inverter, transaxle, HV battery etc.) cause a Prius engine to misfire? perpetually??
    in my reading here on PC I have found one instance where a consistent misfire was finally traced down to a clogged channel in the exhaust manifold itself... can anyone tell me the best way to cross this off the list? laying across the engine block desperately trying not to break the heads off those damn E8 studs by feel alone is not really thrilling, but I'll do it if its the only way...I guess access through the first o2 sensor port wouldn't work to confirm the manifold is clear in all 4 channels? is the fitrst cat being clogged/melted more likely, AND can I gut the cat myself if so? not permanently, but to ascertain if that is the culprit? does this sound like a headgasket issue? thrown rod?? demonic possession or djinn curse???
    my misfire seems to only be the cause of all the racket, which I am thinking is actually the dampening plate slamming back and forth against its integrated springs, which in turn is brought on specifically when the HV battery is in a low SOC... can anyone suggest what my next steps see should be, even tentatively?
    thanks again for all the input, have a great weekend all..!
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,517
    Bay Area, California
    2019 Prius Prime
    How stable is your engine coolant level? How much oil does your Prius use and in what period of time? What codes are present?
    padroo likes this.
  9. Patrick Wong
    18,200
    6,500
    Yes, it would be good to know what warning lights and DTC are currently present.
    You say that the engine idles fine for a brief period.
    Have you tried revving up the engine speed at that point to see what happens? Try to get up to 3,000 RPM or more.
    If the engine can be revved up, how long will it run at a high speed until misfiring starts?
    Can you remove the newly installed spark plugs and see what they look like? Are they tightened to 15 ft.-lb?
    If you are concerned about the exhaust system being clogged, can you just disconnect the exhaust pipe at the exhaust manifold, and run the engine in that condition? (Yes, with 240K miles on the odometer, expect that you will have to struggle with any hardware on the exhaust and things will probably break as you are messing around. Use penetrating lubricant on the studs and nuts and let that soak prior to removal.)
    The water dripping from the exhaust may just be condensation trapped inside the system?
  10. reinerh
    reinerh Junior Member
    port charlotte
    i would try running it like you stole it at this point, meaning drive it hard. you sure have done most all i would have done.
    there is something weird about prius. when there is the slightest misfire, the mg angle is outa whack and it tries to compensate. its very unique to the prius or any other hybrid. i think it can only cause the ruckus you have while sitting, thats why i suggest driving it.
    i seen a video on youtube where this was gone into great detail, but i cant find it at the moment.
    one other thing which comes to mind is that a leaky intake valve caused but oil ingestion, gummed up on the stem. this might not have been caught by your leak down test if its very minor. i think you had cyl 3 being the worst, even after switching coils and plugs.
    maybe you can look in there the intake valves with a inspection camera.
  11. Anil kumar
    Anil kumar Junior Member
    United kingdom birmingham
    Any updates on this
  12. padroo
    2,763
    2,252
    By the way he describes his car it is running in open loop and then when it warms up and goes into closed loop is when the trouble begins.
    I have never heard it mentioned here but there is a situation called "intentional shutdown". It happens when the PCM goes into closed loop and it shuts down a fuel injector with the sole purpose of protecting the cat.
    Shutting the car down it starts all over again, runs for a short time and starts misfiring again.
    I will look for an article on it if I can find one. Scan data would be helpful.
    Here is my source of information.
