Clean busbars made my codes go away.
Discussion in 'Gen 2 Prius Main Forum' started by zuluhotel, Oct 10, 2016.
  1. zuluhotel
    zuluhotel Junior Member
    Gainesville, FL
    Pack was ready to go but kept throwing codes. Cleaned up the corrosion and no more codes! Put dielectric grease on them too before I snapped them back into the plastic. Any more questions give me a shout.
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I plan to perform a buss-bar cleaning and coating as a preventative maintenance procedure as soon as life allows.
    zuluhotel likes this.
  3. zuluhotel
    Gainesville, FL
    Use one of these: a crimped wire cup bush attached to a drill. Take each copper plate out of the orange plastic pieces and brush away the corrosion. Don't worry about soaking them in anything. It won't get you the results you want. After brushing the corrosion, use dielectric grease to keep corrosion away. Hold them with needle nose pliers.
    05PreeUs likes this.
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Nice job Zulu.
    It's never a bad idea to have good electrical connections!
  5. zuluhotel
    Gainesville, FL
  6. Velo781
    Velo781 Junior Member
    32
    Austin
    Any opinion on using this stuff on the terminals of the cell and where they contact the busbar?
    Ox-Gard Anti-Oxidant Compound | Gardner Bender
    I did this after cleaning the busbars thoroughly and no more warning lights. I'm trying to decide if I should have just left the contact areas bare.
  7. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    It's excellent for this application. Dielectric grease is great for sealing connections & contacts. But this stuff takes it a step further -- it's actually conductive, whereas dielectric grease is non-conduction (that's what dielectric means). Either is a good choice, but IMHO, Ox-Gard is a better choice.
    edthefox5 likes this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Ox Gard is an excellent choice. Its made exactly for your application.
  9. padroo
    padroo Senior Member
    2,763
    2,253
    Is Ox Guard the same thing that is used on residential aluminum wiring?
  10. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Yes
