Cleaned fuel injectors, now engine won’t turn over
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wm12782, Oct 25, 2021.
  1. wm12782
    wm12782 Junior Member
    WV
    2003 Prius
    I had the four misfire codes P0301 to 4. Replaced spark plugs, injector coils, cleaned throttle body and mass air flow sensor. After all of that car was running good. I decided to pull the fuel injectors out and clean them. When I had the injectors out the car for some reason the car cycled and started pushing fuel out of the ports where the fuel injectors connect. This lasted about 3 to 5 seconds. The car was not turned on. I cleaned and replaced the injectors. I powered the car up and waiting for the engine to kick on, it tried and I heard a little knock sound as the engine tried to turn over, but it didn’t. Now the engine will not turn over, I hear it try to kick on but it makes a little knock sound every time and doesn’t turn over. Does anyone have any suggestions? Could there be an air lock in the fuel system now because of it dumping that fuel? If so, what’s the fix? Thanks ahead of time.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Injectors not seated correctly
  3. Mendel Leisk
    42,322
    How many miles on it?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    There could be a hydraulic lock in one or more cylinders because liquid gas got in there.
  5. wm12782
    WV
    2003 Prius
    I believe they are because they aren’t leaking?
    328000
    This makes sense to me, any ideas, if I pull the injectors back out will the fuel evaporate and take care of the problem?
    #5 wm12782, Oct 26, 2021
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    Over time, maybe.
    If the engine will try to turn over with the injectors or the plugs OUT, that would be much quicker.
    Edit: on second thought, I don't think the injectors go directly into the cylinders.......but are "outside" the intake valves. If that is the case, then NO and you would need to remove the plugs.
  7. Mendel Leisk
    42,322
    This is a gen 3 (per the forum you're posting in), not a 2003 (per your avatar)?
