Cleaning Battery Fan
Discussion in 'Gen 4 Prius Technical Discussion' started by Deogratias, Apr 26, 2017.
  1. Deogratias
    Deogratias Member
    37
    42
    I have a dog, who is adorable, but is now banned from riding in my Prius, because she sheds profusely. I recently took said dog on vacation with me, and spent most of today cleaning dog hair out of the rear seat and floorboard area as a result.
    The battery vents under the rear seat were fairly well clogged with dog hair. I managed to clean them to the point where they look clear from the outside, but I'm pretty sure if I was able to disassemble the seat/take the vent covers off I would find more dog hair in the vents. Is there a video or instruction anywhere about how to go about the disassembly process?
  2. Prodigyplace
    12,704
    11,846
    Central Virginia
    I have not heard of anyone doing this on a Gen 4.
  3. Mendel Leisk
    42,114
    I would just follow your nose, to get to the fan. It's likely rear seat bottom needs to be pulled off? Also, what are the fan inlet grills like, any screen in them? If not you could add something, like window screen material.
    We occasionally transport our Shiba Inu, who sheds fine fur about 4~5 months of the year. Digging down to the fan every 2 years or so is enough to keep on top of it. And so far on our 3rd gen it seems like fine dust only on the fan blades. We've only had the Shiba about 2 years though, so time will tell.
    That_Prius_Car, RCO and Deogratias like this.
  4. Prodigyplace
    12,704
    11,846
    Central Virginia
    Manual is not too helpful... See the dealer to clean or replace a filter??
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    And there is a second grill in the middle of the seat, but not shown in the Manual - it must do something, but previous discussion couldn't work out what - (it even seemed that some cars were missing it).
    RCO likes this.
  6. bisco
    52,626
    it might be advisable to purchase the service manual for a day. $15. it would have complete disassembly cleaning and assembly instructions.
    a clogged fan can have serious ramifications on battery health. it does sound like you get a warning if flow is impeded, but i wouldn't risk it.
    RCO and Prodigyplace like this.
  7. Prodigyplace
    12,704
    11,846
    Central Virginia
    Perhaps this is why... :LOL:
    From Hybrid Funnies | PriusChat
  8. Mendel Leisk
    42,114
    Maybe...
    Sometimes the car is your best "service manual". Just look at the fan inlet, what it's part of, how that fastens. Then start removing fasteners, gently yoinking things, following the ductwork, you get there.
  9. bisco
    52,626
    easy for you to say, i would end up with parts all over the driveway, and after getting it all back together, i'd find one more part, and no idea where it goes.:cool:
    RCO, Deogratias, alanclarkeau and 2 others like this.
  10. Mendel Leisk
    42,114
    I've been there.
    RCO and bisco like this.
  11. Deogratias
    Deogratias Member
    37
    42
    Mine doesn't have the vent in the middle, just one on each side under the back seat.
    I tried following my nose and gently prying the rear seat up. It wants to "give" but it doesn't. Not sure if I need to use more force or if I'm setting myself up to cause damage if I do that.
  12. Prodigyplace
    12,704
    11,846
    Central Virginia
    Curious. Mine has the same 2 ventsd as @alanclarkeau . I borrowed his picture. The area I circled in yellow appears to take a Phillips screwdriver, possibly to remove a cover for the right vent.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    ...just one more reason most phones now have built-in cameras!;)
  14. alanclarkeau
    7,045
    7,593
    The conjecture at the time was that maybe Li-ION had different venting - mine is Ni-MH.
  15. Prodigyplace
    12,704
    11,846
    Central Virginia
    Good point. So is mine.
    alanclarkeau likes this.
  16. Mendel Leisk
    42,114
    At the 2016 Prius reveal in Las Vegas, Team PriusChat (@Tideland Prius specifically?) did a surreptitious rear seat lift up, for inspection of the battery. IIRC that exposed the battery fan. Accordingly, I think it can be done with bare hands, hopefully doesn't damage anything.
    I believe there's two u-shaped tabs at the front edge of the seat, and if you run your fingers along and find them, yank up right there, it should pop off. Maybe Tideland will weigh in, regarding how to do it, what's visible once the seat's off, if the fan's then accessible, if there's any damage, etcetera.
    I suspect your fan's still going to be quite clean, but worth checking.
    RCO and alanclarkeau like this.
  17. Tideland Prius
    16,642
    RCO, Mendel Leisk and alanclarkeau like this.
  18. Mendel Leisk
    42,114
    Looks like a nylon pocket there, and maybe corresponding pin on the seat above?
