Cleaning car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MikeR5, Sep 3, 2011.
  1. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Where's the rest of the story?
  2. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Yeh, the question is, were you cited for it?
  3. MikeR5
    MikeR5 New Member
    185
    Sherman Oaks
    They cited me for not wearing a seat belt instead. I explained to the officer that I took off my seat belt to get the registration from the glove box. This was my old 83 Volvo wagon- so I couldn't reach without doing that and he even saw me do it! He still gave me the ticket.
  4. Tideland Prius
    16,670
    Hopefully that was the cheaper of the two fines.
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    So they pulled you over for not wearing your seat belt. Makes sense.
  6. MikeR5
    MikeR5 New Member
    185
    Sherman Oaks
    Actually he original pulled me over for no front plate. But the car was from CT- and we had no front plates. So then he said "Well, eating in the car then." And it went form there. I was wearing my seat belt and always wear my seat belt. It feels weird not to wear one.
  7. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Now that makes even more sense. I can see how they can be too trigger-happy to pull someone over for having no front plate especially if they can't see it's from out of state. It was lame of them to make excuses rather than let you go.
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Careful how you wash the car if you are bucket washing it. If not careful, you can add a lot of micro scratching to the finish by wiping with a slightly dirty sponge.
    Can't go wrong with two 5 gallon buckets and grit gards in each never hurts.
    Measure out your soap and water for good mix. Other bucket is to rinse the wash mitt / sponge often. I like using a very light colored wash mitt or sponge so you can see if any dirt on it. Dirtiest part of car usually the lower panels.
    For drying, I use a car drying towel to get bulk of water off an area. I find it worth it to set the towel down and spritz a little spray wax, then finish area with same cloth you would remove wax and buff with. When finished, the car will look awesome plus you've added some wax back on.
    I clay as needed before a wax. Only as needed. If it's smooth and clay glides, that section doesn't needed claying. If clay is picking stuff up, that section needs it. Seems horizontal areas need claying most as stuff falls from above.
    I like Meg's 2.0 Tech Wax spread on thin. I'm about due.
  9. skeptic1
    skeptic1 New Member
    Studio City CA
    I'm seeing some stains on the interior of the door, probably from keeping spare change inside the door handles. I'm worried about trying to wash the "fabric" (more like flocking) on the inside of the doors, but since it's a light color it really shows the stains. Any suggestions?
  10. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I made a mount fo my Navman with a strip of polished stainless steel. I cut off and screwed on the plastic mounting bracket that came with the unit. I used black, gasket grade silicon sealant (sets faster)to stick it down. The sealant just rubs off when I remove it.
    The adhesion is strong enough to resist regular attachment and removal of the Nav unit.
  11. glennhl
    glennhl Member
    175
    Arizona
    The Corvette guys love Zaino products, but I'm too lazy for all those steps. The lazy Corvette owners use REJEX. It's a one step liquid that is very easy to apply and leaves a great shine. But the nicest benefit is you can put it on the exterior plastic and it doesn't leave a white paste. I use nothing but REJEX on all my cars.
    REJEX - Thumbs up! - Corvette Forum
  12. barcelona11
    barcelona11 New Member
    71
    Central NC, USA
    For the cloth seats, I recommend DuraGloss upholstery cleaner. I bought a used Taurus that had been smoked in. Previous owner had a small child as well. After an afternoon and 1 1/2 cans of DuraGloss, it smelled perfect (which is to say not at all), and I removed all kinds of black gunk from the seats and carpet.
    I am not a big fan of interior treatments like fabric protector and dashboard dressing due to the outgassing of VOCs in a tight space where my children and I spend a fair amount of time. I just clean with water or add a smidgen of white vinegar if needed.
  13. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    I use most of the Griot's products, with the exception of their wax. I use P21S - it goes on easily and unlike most waxes, you don't let it dry completely. Very easy to wipe off. The Griot polishes are water based, so after I use the buffer to put on, I just wash the car with soap and water to remove. Their buffer is one of the best on the market - it vibrates and spins slowly. There is no way you can burn/spiral your paint no matter how hard you press. One thing to note about the claybar (which Griot has great prices on) if you drop it - throw it away. It will pick up sand and dirt that you don't want to rub into your paint.
    Car Care, Detail Supplies, Garage Organization, Car Accessories - Griot's Garage 800-345-5789
