Cleaning Dirty Inverter, Advice Please.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by jzchen, Oct 6, 2018.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I actually don’t, but wanted to help keep the inverter stay cool....
  2. Mendel Leisk
    42,259
    Yeah I know, but you can push there till your thumb snaps off, without result. It's around the back of the L-shaped connector too, which makes it very awkward.
    It's absurdly easy though, with a slim blade: just pry through about 30 degree and off comes the connector with a light pull.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Not even knowing where this is in the engine bay, I probably shouldn’t comment, but it does not look like a thumb would work well in such a confined L-shaped area as you note. Maybe an index finger would be better?....
  4. ChapmanF
    18,956
    For some reason my thumb worked really well, and the thing came right off with a light pull. Maybe it depends on where you squeeze? The clip you're releasing is a see-saw; the end you should squeeze is is farthest from the end of the connector. There's a fulcrum, and your squeeze makes the end that latches the connector lift up.
    -Chap
    jzchen and Mendel Leisk like this.
  5. Mendel Leisk
    42,259
    Again, moral of the story: be cautious spraying water down into there; at least one poor soul has had the pins corrode and short out.
    jzchen likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Here’s a shot of our 2010’s this morning when I was checking the oil catch can level:
    77B8F653-AE1E-4043-96EE-C9720743F51E.jpeg BE72D681-C145-43CF-B9AC-DE21FD320BB3.jpeg
    Never have sprayed any water in our engine bay over 9 years and 189 k miles ;).
    I don’t tempt fate in my daily driver(y).
