Cleaning Hybrid Battery Fan -- Pull Orange Tab??
Discussion in 'Gen 3 Prius Technical Discussion' started by woody23, Aug 4, 2022.
  1. woody23
    woody23 Junior Member
    69
    I plan on disconnecting the 12v but I noticed a comment on youtube stating to also pull the orange tab on the main battery. I don't know if he means pull the tab up or pull it out? Is this even necessary?
    "2) You should have unhooked the orange tab on high voltage battery as that could kill you if there is a short. I understand the high voltage battery relay would turn it off if you remove the negative on the 12v battery but just for backup safety its better to pull the orange tab"
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yes, disconnecting the negative battery terminal connection "should" be all you need to do, because in theory, the HV hybrid battery cannot be activated via a solenoid without the auxiliary battery connected.
    Just don't do the maintenance with a battery charger connected up front and you should be good to go. YMMV
    woody23 likes this.
  3. Mendel Leisk
    41,889
    I didn't, and don't think it's necessary. You're not opening up the hybrid battery; just cleaning some ducts and dusting the fins on the (12 volt powered) fan.
    woody23 and xliderider like this.
  4. Mendel Leisk
    41,889
    Should clarify: I didn't disconnect either battery.
    mikey_t and woody23 like this.
  5. ChapmanF
    18,531
    I wouldn't either. As Mendel says, it's just a fan in some plastic ducts. If you wouldn't fuss with battery disconnection to change a headlight bulb or a horn, this isn't much different. Just have the car turned off, so the fan isn't spinning while you clean it. :)
    Unless you're going to pull off a duct that exposes the high voltage frame wire terminals.
    woody23 likes this.
  6. woody23
    69
    Thanks guys. I just left the 12v and the orange tab alone. Fan wasn't too dirty either. Just a thin layer of caked on dust on the fins. No hair or anything. Got it cleaned up pretty good.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    I agree with just disconnecting the negative terminal on your 12-volt battery just to be sure it's not going to come on.
