Cleaning MAF -- need new O ring?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Sep 28, 2014.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    I am trying to solve another problem.
    But, it was suggested I clean the MAF. I did this LOOONG ago on a Ford Mustang, but it was really simple, IRRC, on the Ford. No need to remove the MAF.
    On the Prius, have to remove the MAF. My Chilton's book says I have to replace the O ring if I remove the MAF.
    Sounds reasonable. Except, no O ring to be had on a Sunday afternoon in ruralville. Is the new O ring a necessity?
    kris
    #1 cyberpriusII, Sep 28, 2014
  2. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    Unless it looks damaged I wouldn't worry about replacing it this time. Some might put products like Super Lube on when reinstalling to keep the O ring in good shape.
  3. Patrick Wong
    18,210
    6,517
    The Toyota repair manual does not require O-ring replacement as long as it is in good condition, as previously stated.
  4. cyberpriusII
    1,157
    1,850
    Hyampom
    Makes sense, but won't know until I pull it off. And then I am stuck....well, irregardless of my current situation...it is good to know for the future!
    Thank you Exmetrodriver and Patrick!!
  5. Patrick Wong
    18,210
    6,517
    Your car is only 5 years old and presumably the MAF sensor has been undisturbed until now - so I would say there is a high probability the original O-ring can be reused.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I removed the MAF in our '04 Prius numerous times over the years. Now that I remember that it has an O-ring, I can say that it always looked to be in fine shape.
    CP: If your car's MAF O-ring does look ratty, don't sweat it. Just buy the part when you pass by a Toyota dealer and exchange it. You'll find out from the cleaning that putting in a new ring is trivial.
    <soapbox>
    I have been following the threads and posts of owners who have maintenance and simple repairs performed by dealerships, and overall it seems that dealership service(s) are five to 10 times the cost of DIY. So while you are somewhat stuck going to the dealer for the pump replacement this time, I encourage you to join the DIY band-wagon in the future. This forum has great tutorials (most often written by Pat Wong), and lots of help if needed. Youtube has great videos. The trick is to not wait until emergencies force your hand.
    </soapbox>
    #6 SageBrush, Sep 28, 2014
    exmetrodriver likes this.
  7. cyberpriusII
    1,157
    1,850
    Hyampom
    Agreed!
    And have tried to the best of my limited ability. But, this is from a person who had trouble getting to the cabin filter way back in 2009.
    Since that time I have replaced/cleaned said cabin filter many times. Changed oil and filter. Changed engine air filter. Replaced 12v battery. Rotated tires. Installed a "brace" of some sort (that was a few years ago, went under car and replaced the OEM brace). Screened off all "mice access points" -- or so I hope, and a few other things.
    I HAVE been trying, but to be perfectly honest, sometimes I get a bit scared that I will do something that will result in major damage either to me or the car. For example, hooking up the mini-vci, I was sure I would fry something in the electrical system.
    Still, with your help and the help of others here, I feel that while I may not be very far along, I am crawling a bit ahead anyway -- which is better than nothing.
    But, overall, once again, thank you and everyone else for the help. Really!
    And, even if I don't repair the water pump myself, I do feel somewhat (O.K., barely) proud that I did discover the issue myself.
    Next the MAF...
    Kris
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Kris,
    If you decide to start a support group for blind monkeys with wrenches, let me know. I'll be the first to join.
    Seriously, it would be hard to find someone less mechanically inclined than me, and I had never tried to do anything on any car I owned until I bought a Prius.
    What changed me ? Interest in the Prius, this fantastic forum, and watching lots of YouTube videos.
    Sounds like we have traveled much of the same path: first simple maintenance, then more involved things in small steps.
    By the way, Hobbit's Prius website is just unbelievably fantastic, and the Bentley book on the Prius is money VERY well spent.
    A not small part of replacing a wear part in a Prius is just getting to it. The first time can be a bit of a bear; the second time isn't so bad, and thereafter it is easy. So I have also been known to just disassemble small parts of the Prius just to gain confidence and learn about the part(s) involved -- before actual work is required. I have also found that buying parts that I know will eventually require replacement way ahead of time is a good idea. Not only does it let me pick when I want to work on the car, I have ample time to fiddle with a clean part and gain a degree of familiarity.
    There is a Zen about new cars in general, and Prius most of all, that is helpful to grasp: cars are engineered these days so that with good maintenance of filters and fluids, cleaning/lubrication of a few areas , and timely replacement of wear parts by design, unexpected and costly repairs are rare. Neither of us will ever understand our cars very well, but we are all capable of keeping our cars happily running for a decade or two and for the most part, out of the clutches of expensive dealerships.
    Cost? Maintenance+repairs, about a penny a mile for the first decade, I guess 2 - 3 cents/mile for the second decade. Tyres are extra ;)
    #8 SageBrush, Sep 28, 2014
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Kris, I'm copying a post of mine from another thread you might find useful.
    I set the car on 4 jacks so that I can rotate tyres while the oil is draining.
    The car really does lend itself to multiple maintenance items at one time; it just takes a little planning
    I work on my car once a year (10k miles), and perform the following 4 of every 5 years:
    1. Cabin and Engine filter checks, replacement if needed
    2. Oil exchange, oil filter exchange
    3. Tyres rotated
    4. One gallon (partial) Engine coolant exchange
    5. CV boot cleaning and spray with silicone
    Every 5th year, the above is done and in addition
    • Brake pins are lubed, pads and rotors are checked
    • Inverter coolant exchanged
    • ATF
    • Brake fluid check for pH, water and copper; dealer flush if required
    • MAF and throttle plate/body cleaning
    At 10 years, the above is performed and in addition
    • Spark plugs
    • PCV
    • Serpentine belt
    • Engine pump
    • Front struts if needed, or if I am in the mood
    So nine years out of ten, maintenance amounts to a couple of hours one time a year. Year ten takes all day because of my unfamiliarity with struts.
    I forgot to mention, the free to you but very important to the car monthly routine:
    • Check engine oil level
    • Check brake, steering, and coolant levels
    • Adjust tyre pressures
    #9 SageBrush, Sep 28, 2014
  10. JC91006
    16,936
    8,647
    I don't recommend anyone messing with brakes and struts unless you are very familiar with what you are doing. You risk serious injury or maybe death if it's done wrong.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    That is how I feel about the inside of the traction battery, but I've pretty much decided to install a new pack myself if the time comes.
    YMMV. Almost everybody can DIY the yearly and 5th year maintenance; 10th year stuff varies by owner.
    #11 SageBrush, Sep 28, 2014
