cleaning maf sensor
Discussion in 'Gen 2 Prius Technical Discussion' started by tamvette68, Mar 19, 2014.
  1. tamvette68
    tamvette68 Junior Member
    newbe here and learned a hellofalot off this forum...most you guys and girls are prius geniuses and I thank all in advance. I have a 2008 with 75K miles and had it just a short while but love the car. I'm wondering if I can clean the maf sensor with it remaining in the air body using crs maf sensor spray or does it have to be removed? If removed, can the sensor body just be removed?
  2. Patrick Wong
    18,199
    6,464
    Remove the mass airflow sensor from the air cleaner housing to facilitate cleaning. This is quite simple, two screws.
  3. tamvette68
    thank you sir
