Cleaning steering wheel
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by booke02, May 19, 2019.
  1. booke02
    booke02 Active Member
    391
    415
    Israel
    My steering wheel feels a bit sticky, although I give it a periodic wipe with a damp cloth. Seems like that is not enough to remove the stickiness. Anyone have any experience with cleaning the steering wheel of 2016? Any cleaning materials to be avoided, or materials that have worked well without causing any damage?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is yours leather or synthetic? I suspect mine is synthetic - the USA manual says:
    Do you cover your wheel when it's in the sun (parked)?
  3. booke02
    391
    415
    Israel
    Alan,
    I assume that my steering wheel is synthetic. I don't cover it when parked, although the car spends most days in shade.
    I wonder what qualifies as "neutral detergent?"
  4. alanclarkeau
    7,045
    7,593
    upload_2019-5-19_23-41-33.png ??
    booke02 likes this.
  5. Kenny94945
    Kenny94945 Active Member
    859
    434
    Sausalito
    2016 Prius v wagon
    Is the stickiness from human hand residue/ grime or is the stickiness from the wheel's material?
    If hands, natural detergent....hand soap and warm water.
    Many other forums suggest Woolite (brand name) has a really good cleaner.
    If the wheel's material is failing, more than likely caused by some other detail product/ interior care product.
    Other than wrapping or replacing, I don't have a suggestion for this.
    "Sticky buttons" in Ferrari's can offer you a good search as to what can happen over time or use of some detail chemicals.
    You've got some options; let us know and good luck.
  6. TinyTim
    TinyTim Active Member
    388
    238
    Seattle
    Perhaps a little goo gone spray gel. Home depot has it. Not the pro level stuff but the liquid gel in the spray bottle.
  7. booke02
    391
    415
    Israel
    I think that it is simply hand residue/grime. Definitely not from any other care product. I will give a try with hand soap and warm water.
  8. krmcg
    2,592
    2,393
    Whittier, CA
    I find it hard to clean the Goo Gone off of surfaces after I use it. Alcohol is often required.
  9. TinyTim
    388
    238
    Seattle
    Not the kind of goo gone that I listed. That stuff is designed to take off sticky substances like packaging tape residue. The heavy duty stuff is the liquid that comes in the lighter fluid canister.
  10. alanclarkeau
    7,045
    7,593
    I'd be wary of anything with a solvent type action.
    Neutral detergent - I guess something like highly diluted hand- dishwashing detergent
  11. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Do you use ArmorAll? The steering wheel on my 2008 Prius did that after about six years.
  12. RRxing
    RRxing Senior Member
    2,557
    1,831
    NEPA
    Something like Simple Green? Diluted as indicated above...
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Neutral means ph7 not acidic and not alkaline. see: pH Scale
    alanclarkeau likes this.
