Cleaning the EGR cooler. Or Not!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boffin, Mar 11, 2020.
  1. Steve R. Burns
    Steve R. Burns New Member
    Fairfield, IA
    Thanks Wendel, for your very helpful reply. As a ChatGPT addict I asked for further clarification on the issue. An earlier question to it had stated an extreme scenario. You might enjoy seeing its answer to yours, below. (A much longer detailed answer with step-by-step DIY guidance was given. Too long to post here. I can send direct if you like. But none of it likely news to you. Its detail was impressive though. ChatGPT is helpful...most of the time :)
    "The EGR cooler stud can be difficult and nerve-wracking. Breaking it does not doom the engine. Mendel omitted reinstalling it because it is non-critical. Shops over-warn because of liability, not because of real danger. ChatGPT earlier advice leaned toward theoretical worst-case. Mendel’s answer reflects hands-on Prius reality."
  2. pasadena_commut
    pasadena_commut Senior Member
    3,076
    956
    Southern California
    Hypothetically...
    Regarding the problematic stud on the EGR cooler, the one that is oriented perpendicular to the two studs at the end of the cooler. After reading a bunch of these threads it seems that some people leave it off, and some others even cut off the bracket that the stud passes through. Since I think Toyota most likely had a good reason for putting that support there, perhaps a middle ground is possible? After removing that stud with an E8 once, pull out the EGR cooler, then grind a slot into that flange, same size as the existing hole, or slightly larger (not enlarging the existing hole), from that hole towards the rear of the car. Then reinstall the stud. Seems like after doing that one could remove the EGR a second time by just pulling it towards the front of the car (after the nuts are off the 3 studs), and that support point would be mostly intact. About 2/3 of the contact area for the nut would still be present, and the flange/nut would still keep the cooler from moving at all in that region.
    I have not done this, but it seems like it should work. Unless maybe there is something in the way that would prevent the EGR cooler from sliding past the length of the slot so that the flange clears the stud.
    My first thought was to carefully cut the slot into the flange before taking the EGR cooler out. Then the stud would never need to be removed, so no E8 needed. However, that seemed like it was just begging for a hand slip and serious damage to some part that would not take kindly to a visit from a Dremel or similar cutting tool. Also metal bits all over the inside of the engine compartment, which is rarely a good idea.
  3. Mendel Leisk
    42,383
    I can't imagine cutting a slot in that bracket, considering it's location. You can't even see it. I'm not sure why people want to perform surgery, just back the stud out, done.
    That said, "just backing the stud out" is not easy, considering the location, and all the blinking cables and brackets in the way. I was JUST able to get a 1/4": drive ratchet with E8 socket on it, and achieve enough wiggle room to get one click at a time, out of the ratchet. It took me about 15 sweaty minutes, click by click, and fighting due to dissimilar metals, all the while. There's no way I would reinstall it.
    My take, Toyota did NOT anticipate this mess, neglected to test this new EGR system, didn't appreciate it would be come a mandatory maintenance. So buried it in a morass of cables. We're pioneers.
    #83 Mendel Leisk, Feb 1, 2026
  4. DJLand
    DJLand Junior Member
    Ontario
    Four Touring
    Greetings all. So much information. I've just bought a 2014 Prius V with 115000 km (71000 miles). I was looking for a while and had been avoiding Gen 3 because of the EGR problems I'd read about on here but decided that a lower milage, well maintained V was not a big risk. It's much bigger that the 2008 we've run up to 410,000 km (255k miles) and burns more gas but still much less than anything not electric with as large a cargo volume. And it runs great.
    I plugged in my ELM 327 OBD device and looked at the test results with paid Torgue app. I found
    EGR Flow suffiency (.99 min - 655 max): Pass; 19.23 kPa,
    which seems fine per some other threads here. It also showed a 2 current and a couple dozen accumulated misfires on cylinder 3.
    So I'm thinking I won't dive into removing/cleaning the EGR system at this time to save the money and time and risk of screwing something up. I'll keep an eye on the EGR flow kPa as I go. If it starts to decline, at what point would it be prudent to do the cleaning. Is it best practice to do it at 100k miles or some other point? Do I wait for the idle to become rough, or is that too late? Most of our driving km is on 100+ km trips though of course most trips are shorter. The car was dealer maintained before now; though I don't know if an EGR cleaning was done, I expect not.
    Thanks in advance for sharing any thoughts and experience.
  5. Mendel Leisk
    42,383
    Lot's here will tell you that's prudent. Myself, I'd be cleaning it.
    Some relevant links in my signature. (on a phone turn it landscape to see signatures)
  6. DJLand
    Ontario
    Four Touring
    So many Vs are in use as taxis in fleets that I wonder if the shops that maintain them have, through long experience, figured out the most effective, reliable, and economic strategy to deal with this problem.
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,151
    6,989
    Texas Hill Country
    They just change engines when they blow. brake boosters when they code and hybrid batteries when they lose capacity. The economics for a taxi company are good and they have extra vehicles to cover the downtime.
  8. Mendel Leisk
    42,383
    The time is basically a leisurely weekend. You "can" bang it out in one day I suppose. My approach is one afternoon, a bit more in the evening, mostly just reassemble the next morning.
    The money required involves a can or two of brake cleaner, some caustic cleaner for the cooler, and maybe a new set of the pliable gasket on the intake manifold ($30~ for the latter).
    My slightly educated (by reports here) for an appropriate interval is 50k miles maximum. Considering how the systems innards look eight-o-clock-day-one, and presumably that's what the engineers are counting on, I'd want to keep it roughly thus.
    #88 Mendel Leisk, Aug 24, 2026 at 10:01 AM
