Cleaning the Prius Hybrid Fan for Preventative Maintenence
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DevChatt, Dec 22, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I have a set of picks in the garage that would probably work;).
    The angled ones do the trick(y).
    JC91006 likes this.
  2. JC91006
    16,768
    8,565
    That fan TMR cleaned out is really clean, especially when you look at what he started with. I need that secret sauce
    jerrymildred and Raytheeagle like this.
  3. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I bet the secret sauce contains elbow grease and a touch of determination ;).
    JC91006 likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Probably chicken grease. Works great on my hands after working on my brakes.
    JC91006 and Raytheeagle like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    II split the housing to get good access to the fan. Then use a small "tweeker" flathead screw driver, about 3/32 or 1/8 inch wide, that has the tip rounded so it's close to the same curvature as the fan blades. A bit of scraping and then some paint brushes that have been trimmed back to shorten the bristles to make them more stiff. And of course, an air compressor. One day I'll just take one of my extras and see what needs to be done to just yank the fan off the shaft and then clean it in a sink. The wife will love that.
  6. JC91006
    16,768
    8,565
    Air compressor....Yes, that's the secret sauce. I think that'll blow all the crap out of the crevices.
  7. Texas Hybrid Batteries
    Texas Hybrid Batteries Senior Member
    271
    563
    Dallas -Fort Worth
    This is one of my favorite so far.
    I clean a lot of fans so sitting there and picking between each blade is not an option. We pre clean them with compressed air and then spray the squirrel cage with a little degreaser and let it sit for a minute. Rinse with warm water and it comes out looking like this, no elbow grease required. Just make sure you hold the housing in a way that all water runs off when rinsing and it'll be fine.
  8. JC91006
    16,768
    8,565
    Can't damage them by rinsing with water?
  9. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    Wow. That's foul. Were they transporting sheep or llamas in their car?
  10. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Heheheheh! So you're rock fan like me? I don't think @bisco is either:eek:
    bisco and Mendel Leisk like this.
  11. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Are you pointing that barrel at me?:D
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Is there a way I could bench test these fans from off the car, using a 12volts battery?
    I would want to use some of the hihy blower fans have got lying in the shop, to construct a housing to help keep some of the modules or pack I charge, cool.
  13. JC91006
    16,768
    8,565
    Yes, just buy an extra fan harness and connect to 10A power source
    Raytheeagle likes this.
  14. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    OK. Do I have to connect the harness to all the about six wires coming out of the blower fan?
  15. Texas Hybrid Batteries
    271
    563
    Dallas -Fort Worth
    Not as long as you don't let water run back into the motor. I rinse them with the housing split and then blow any residual water out with compressed air. Then follow that up with a few minutes running on the bench. Probably done a thousand that way and never had a problem.
    Gen3 fans are another story. The design on those makes it hard to rinse without wetting electronics. It's a brushless motor mounted on a circuit board vs the traditional brushed motor in the Gen2. On Gen3's we have a way to remove the squirrel cage from the shaft and wash it separately.
    #35 Texas Hybrid Batteries, Dec 23, 2017
    davecook89t likes this.
  16. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    +1
    On our 2007, I had the fan out and actually stuck it under a faucet after not being able to get all the dust out with Q-tips. (I left it to dry for a couple of hours before putting in back in, of course). It's been more than a year, with no problems. I know it is still fully functional because of an incident I had this summer, described here:
    58.4 C (137 F) Temp on HV Battery per Torque Pro | PriusChat
  17. Mendel Leisk
    41,407
    If you're just doing the one fan (your own) I would think it's much simpler to just dry clean, leaving the fan in the car, than to completely remove in order to wash it out. It may take longer cleaning, but not much. I Used q-tip in between the fin blades, and vacuumed up the bits. Q-tip is ideal size, just fits snugly between the blades.
  18. Mendel Leisk
    41,407
    To be fair: ours was not very dirty though, I'm a bit obsessive.
    Raytheeagle and davecook89t like this.
  19. davecook89t
    1,089
    825
    Four Touring
    ;), same here.
  20. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    DevChatt and davecook89t like this.
