Cleaning up cloudy yellow headlights
Discussion in 'Knowledge Base Articles Discussion' started by fotomoto, Jun 9, 2018.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Same here!
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Well they are all cleaned up! Nowhere near "new" clarity, but very good overall. Did not get before photos, but the headlamps were as bad as most before I started.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    More cheap and easy headlight cleaners include toothpaste and baking soda. They're both such fine abrasives that they remove the yellowing without scratching the lens covers. Baking soda works even quicker if you spray a bit of vinegar on the headlight first, but if you get cravings for fish and chips, you've been warned. ;)
    05PreeUs likes this.
  4. GoodOldBob
    GoodOldBob Member
    67
    25
    Mena, AR
    2020 Prius
    L Eco
    " I simply use rubbing compound found in most automotive sections and it works GREAT!……... use the turtle wax rubbing compound brand "
    I love using rubbing compound. I had some Ukuleles that had a satin finish and a little elbow grease along with some rubbing compound had those Uke's looking glossy in no time. Thanks for the tip!
    #24 GoodOldBob, Oct 14, 2023
    Merv Himself likes this.
  5. sylvaing
    sylvaing Senior Member
    1,221
    517
    Meguiar's ScratchX works great on
    cloudy yellow headlights. Takes just a few minutes with a microfiber towel. No need to use a drill and its inconvenience (ie, time waisting masking off the surrounding area and product flying all over the hood and bumper). Be sure to apply a UV protection afterwards otherwise you'll be repeating the same procedure within the year.
  6. Merv Himself
    Merv Himself Junior Member
    71
    Georgia, Florida
    2013 Prius v wagon
    I've had good success doing it the old fashioned way with very fine grit sandpaper and a fresh coat of UV resistant polyurethane.
  7. Mendel Leisk
    42,358
    I did a little French polish furniture refinishing: you start with pumice on a felt pad, then switch to another with rottenstone.
