Clear protective film on the hood
Discussion in 'Prius v Main Forum' started by Glenaby, Aug 2, 2024.
  1. Glenaby
    Glenaby Junior Member
    Houston
    2015 Prius v wagon
    Hello All,
    I bought a used Prius V a few years back that had a clear protective film in several places. I dont know who installed it. This had been a lease so I am assuming it was applied by Toyota or the Dealer. Over the years the piece on the hood has deteriorated forming cracks and looks bad. Anyone else have a similar experience? any advice on how to remove it? IMG_0092.jpeg
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,121
    6,977
    Texas Hill Country
    The vendors who install ppf film are best at removing it. Removing it incorrectly is almost guaranteed to pull up some paint.
  3. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    installation instructions are here
    How To Install Paint Protection
    removal isn't much different than the reverse of the installation
    spray - grab a corner an pull slowly - rinse and repeat
  4. Glenaby
    Houston
    2015 Prius v wagon
    Thank you!
    vvillovv likes this.
  5. rjparker
    11,121
    6,977
    Texas Hill Country
    Don’t do that!
  6. Mendel Leisk
    42,355
    I removed the two little bits that get put on at the factory (on our gen 3 hatchbacK), ant the rear door edges. I (gently) played a heat gun on it, picked at an edge to get started, took my time, keep it warm and slowly pull. Finished up with a little was; you'd never know it was there. Hood's a much bigger area though. You might end up with some difference in colour too, once it's off.
  7. vvillovv
    4,337
    1,519
    NY
    spraying the water solution is the easiest and safest way IMO. Just don't get the two different water solutions mixed up. One sets the film in place, Don't use that one when removing film.
    The other keeps the film from sticking until it's aligned and air bubbles removed while installing. use that one and keep spraying it and getting it under as much as it will go. Once you get the film started you'll see how the water solution works at keeping the film from sticking.
    Others have their own thoughts and warnings to share.
    What sized sheet's on the hood?
    There are at least 3 sizes I've heard of and none of them even the biggest one goes up onto the flat part of the hood by the windshield/
    #7 vvillovv, Aug 3, 2024
