Clearcoating headlights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AK18, Sep 4, 2016.
  1. AK18
    AK18 Member
    45
    83
    SoCal
    Been trying to restore my headlight assembly for the last couple days. Tried many products out there including Turtle Wax, Mothers and finally got the one that yield best result, which is Meguiar's PlastX.
    Started by wet-sanding the headlight and then when I finished, I tried to clearcoat it by using the Rust-Oleum 2X clearcoat. It's been an hour and this is what I'm seeing. Not clear....what did I do wrong?? 1473024766087.jpg 1473024771151.jpg
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    try headlight restore from walmart, the clearcoat is way better
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Final wet-sanding needs to be the very finest grit you can find, then follow that by using toothpaste (yup, toothpaste!) then clearcoat! (lots of how-to videos on youtube!)
    Gnarly likes this.
  4. AK18
    AK18 Member
    45
    83
    SoCal
    I finally figured it out...after clearcoating....we need to wet sanded again with 5000 grit...and then re-polish...now it looks pretty!!!
    Threej likes this.
  5. Mendel Leisk
    42,343
  6. AK18
    AK18 Member
    45
    83
    SoCal
  7. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    Does look good now.
    Question for you though, is that the 2013? Did the clear coat fail that quickly in So Cal?
    My 2010, 2009 July build has been outside since I bought it. There is now some evidence of factory clear coat failure on the top of the housings, not at the front where the light shines out, but it would still be overkill at this point if I would be seen taking sandpaper to them. It really is just a little bit of haziness that looks like the after effect of being parked in a shower. Enough for me to see, not a normal person, but I am a picky bugger when it comes to my Prius.
    Like to know and wish that your respray holds up for a good long time.
    Roland
  8. AK18
    AK18 Member
    45
    83
    SoCal
    The headlight was pitted when I got the car but the lens are not yellow. So my primary goal was to remove the pitting which I did by wet sanding the lens. Then clear coating for longetivity...
  9. Roland1555
    282
    69
    Vancouver BC
    Oh okay.... I've plenty of highway miles but very little pitting thankfully.
    Wish I could say the same for the hood, I suck at using the little touch up paint on the blizzard pearl finish.. always seem to see the 'repair' almost more than the original chip.
    One day I will try the clear coat method you detailed here for us on the lamp housings as I think the little hazy area I see will gradually expand more quickly now that it has started. Just waiting as I think the original coating is apt to last much longer than the Rustoleum spray, but it would be great if your coating lasts a long time as I hope it will.
    Roland
  10. AK18
    AK18 Member
    45
    83
    SoCal
    Only time will tell....but if you do get the clearcoat, make sure you ONLY use the Rust-Oleum 2X clearcoat ...no other brand. I tried different rust-oleum..only to find had to re-send everything and start over. Now come to think of it, not sure how thin the plastic has become...ha ha ha
  11. Roland1555
    282
    69
    Vancouver BC
    That is the one I already bought. Way too far in advance of the job as I said.... I like to be prepared, just hope the product doesn't degrade in the can before I deem it necessary to go for it.
    I was relieved to see the exact can that you pictured above.
    thanks for the head's up. And hope you have lots of plastic left on those housings.
    Roland
  12. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    There is also a 3M vinyl product that can be applied to the headlamps. It's optically clear, and provides some impact protection (rocks etc). Expensive though. Almost as much as new housings.
  13. Danger
    Danger Member
    175
    22
    Frisco
    AK18 - What polish did you use? My headlights have clearcoat peeling a bit and I want to restore it like yours.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    image.jpeg I did my headlights this morning.
    Have some before and after shots. They look like brand new lenses using the Turtle Wax kit. Bought the rust oleum clear coat, but didn't use it. Want to see what the longevity of the turtle wax lot is before I put too many variables together;).
    kc410 and Roland1555 like this.
  15. Roland1555
    282
    69
    Vancouver BC
    Hope it lasts for a good long time and that you will let us know.
    Raytheeagle likes this.
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I am hoping so. I let them go until it got close to the low beam projection outward.
    I will provide updates once they fade again. The more actual data the better:).
    kc410 and Mendel Leisk like this.
  17. SB6
    SB6 Member
    324
    71
    How are they now, two years later?
    Mendel Leisk and Raytheeagle like this.
  18. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Ended up following up with wipe new as the turtle wax kit didn’t last as long as I hoped (about 9 months) :(.
    Here’s a shot tonight after a year and a half on the wipe new kit:
    7ACD070D-2F00-4175-8B48-617403432A9D.jpeg 15BBF18B-B654-4424-821F-C3264A464B21.jpeg
    I’ll have to follow up again soon, but not bad for a year and a half;).
    Thanks for circling back and asking for data(y).
    SB6, RMB, Merkey and 1 other person like this.
  19. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Time to buy new ones ;) you’re just avoiding the inevitable :ROFLMAO::ROFLMAO::ROFLMAO:
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Meh, a $10 kit every 2 years ain’t so bad;).
    New headlight assemblies run more than $20 each, so cost justification on a nearly 10 year old Prius isn’t there :cool:.
    I’ll keep going the kit route(y).
