Click sound over 80 km/h
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Alibaba9211, Aug 20, 2021.
  1. Alibaba9211
    Alibaba9211 New Member
    Ottawa
    2018 Prius
    Hi
    I have Prius 2018 base model with 68000 km on I am facing a problem when driving over 80km and start to change line as turn the steering wheel right or left I hear a click sound 2 times It’s happened only over 80 km not before and sound is like when you press a soft metal plate and it goes down with click and as you release pressure it comes back to normal with a pop up click sound. I have changed the front right side wheel bearing along with all 4 brake pads and routers. Cv boots ball joint suspension and all major items has been checked all ok Some says it’s not mechanical problem it’s kind a flasher or relays sound or something related to line assist. Please help me with this issue I have recorded the sound but can’t attach it here. Thanks
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    What do you mean - driving over 80 kilometres? You mean after it's well and truly warmed up?
  3. Alibaba9211
    Ottawa
    2018 Prius
    No not warm up. When ever you drive and cross 80 km per hour and you start turning your staring wheel you hear click click 2 times Every time over 80 km it’s happened. And it’s behaves normal at 78 or 79 km
  4. Mendel Leisk
    40,530
    The title explains?
    Post the text of your (YouTube?) title, and someone can search for it, post a link.
    I think you just need to be here a few days, have more posts, and that’ll be unlocked for you.
    alanclarkeau likes this.
