clicking noises upon braking 2016
Discussion in 'Gen 4 Prius Main Forum' started by prius_deep, Oct 7, 2017.
  1. prius_deep
    prius_deep Member
    105
    38
    road
    sounds like a 2008 in the video.
    Have a 2016 I have not had the issue. I bought a used 2008 and it emit a clicking sound(s) on breaking (sometimes), and sometime while the car (2008) is off [while I am around {FOB}].
    there is warranty for gen 2 Brake Pump/actuator replacement to the end of this year. Hope the 2016 is not going to have the same issue!
    anyone with a 2016 hearing clicking when breaking and or breaking and turning right?
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    In front wheel drive cars (not just Prius) this is usually a symptom of wear in the constant velocity (CV) joints. They wear especially quickly if the protective rubber boot is damaged.
    kevin
    RCO likes this.
  3. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I have a similar noise coming from the front left disc brake. I had it checked and I was told by the dealer that the disc as some radial unevenes due to rust which will then make a sound when hitting the brake pads.
    They told me it should disappear after usage.
    After 6 months it has reduced somewhat but still there....
  4. Mendel Leisk
    42,361
    There's been a couple of posts now, with videos, regarding ticking sound while braking. And of course I can't hear anything, any distinct ticking noise, lol. Are others able to hear it? Maybe you've get a better positioned mike??
    RCO likes this.
