Clicking sound in front when braking while turning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jimbo8285, Feb 11, 2012.
  1. jimbo8285
    jimbo8285 New Member
    Tallahassee
    I have a 2010 Prius. Recently when coming to a stop and turning I hear a clicking sound coming from the passenger side front wheel. It only does it when slowing to a stop and making a slight right turn.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    get your joints checked
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    That is the classic sympton of a failing CV (constant velocity) joint between the transaxle and the wheels.
    How many miles do you have on your car? That seems very early for a 2010 car.
  4. jimbo8285
    Tallahassee
    Only 35,000
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    That should be covered by 3/36 warranty. Get to a dealer asap.
  6. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    MAKE SURE ALL LUG NUTS ARE ON AND TORQUE ACCORDINGLY THEN.
    Check CV joints
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Might also be bearings... jack the front up and check for play in the wheels. But yes, get it in to the dealer...
