Clicking sound underneath when driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daisy555, May 4, 2023.
  1. daisy555
    daisy555 Senior Member
    1,727
    715
    CT
    Hi!
    When I’m on a sharp right turn at entry to highway, I hear a clicking sound under car. Similar tinny sound I heard when a small part needed to be replaced after catalytic converter was replaced. Service manager will be doing test drive later this morning. Doesn’t occur during similar turn to the left.
    Any ideas?
    Thanks!
  2. BiomedO1
    BiomedO1 Senior Member
    4,320
    2,268
    Left Coast
    most likely a bad CV joint on one of your drive axles.
    daisy555 and Tombukt2 like this.
  3. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Agreed. That is exactly what my 08 sounded like. A visual check of your CV boots might find a ripped boot. Check for grease being flung all over. CT winters and age of car suggests that as well.
    daisy555 likes this.
  4. daisy555
    1,727
    715
    CT
    Ugh! Thanks Is this an urgent repair? I’m hopefully getting new Prius within next few months.
  5. daisy555
    1,727
    715
    CT
    Thanks!
  6. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    Well. If you CV Axle is toast then it is toast. It will continue to work as long as there is grease in the joint. Once all the grease has been flung out it might seize. This could take awhile. IMHO you could drive it for another couple months... Just listen for the clicking. It should get louder and louder.. the worse it gets. After Market axles are like $80-$100 pretty easy to install. maybe 1.5 hour of labor?
  7. daisy555
    1,727
    715
    CT
    They are looking at it now. Service manager doesn’t think it sounds like CV joint.
  8. daisy555
    1,727
    715
    CT
    They examined CV joint. No tear or grease. Maybe beginning stages of a problem. Also not a wheel bearing sound. He’s suggesting for now that I wait to see if noise changes. He knows I’m waiting for a new car and have this road trip to take.
  9. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    hmmm. Ok. Well this is a new one for me...Keep us posted. Thank you.
  10. daisy555
    1,727
    715
    CT
    Thank YOU!
