Clicking sound when stepping slightly on gas engine.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ratanakly, Apr 24, 2021.
  1. ratanakly
    ratanakly New Member
    Phnom Penh City, Cambodia
    Hello everyone,
    I am having clicking sound when my Toyota prius 2010 was trying to charge the hybrid battery at low two bar and stepping slightly on gas engine. This usually happen at the point Stop of traffic light, i have replaced the sparkplug, coil, and cleaned intake manifold, egr system including cooler but the sound have not gone.
    Please help!
    TQ
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,145
    6,988
    Texas Hill Country
    Possible pinging/preignition caused by carbon buildup. Most evident with a low hv battery on initial acceleration. If you have access to high octane gas, eg around 93 US standard, try a tank. If the sound goes away it is pinging.
  3. ratanakly
  4. rjparker
    11,145
    6,988
    Texas Hill Country
    That sounds like head gasket.
    ratanakly likes this.
  5. Mendel Leisk
    42,380
    How many miles on it?
  6. ratanakly
    Dear all,
    My car is about 120 mile and the Coolant level is okay. I am trying to record its sound but can not upload here, hope that the below link is worked.
    Link Sharing
    Tq,
  7. Jenny2010Prius
    Jenny2010Prius Junior Member
    37
    Calgary
    2024 Prius Prime
    SE
    Have you found out the cause of the noise?
    We started to hear some kind of quick clicking noise when accelerating lightly with gas engine after 260K KM (160K mile) with our 2010 Prius. Doesn't matter if the engine is cold or warm. Most noticeable at lower speed (may due to lower tire/road noise). No noise when the gas engine is off, i.e. the car runs on battery only.
    It sounds like some thin sheet metal vibrating under the chassis. Checked for loose exhaust pipe or heat shield. But all parts are secure & not loose.
    Also just cleaned intake manifold, EGR pipe/valve/cooler, PCV valve not that long ago in 2022.
