Climate Auto/Off and A/C - EV range
Discussion in 'Prime Main Forum (2017-2022)' started by sylvaing, Aug 13, 2024.
  1. sylvaing
    sylvaing Senior Member
    1,210
    514
    So I understandably, when you turn off the climate, the calculated EV range goes up since the heat pump isn't being powered, but why doesn't the same thing happen when you turn OFF the A/C itself (but still in Auto)? In the multi-information display, it even shows no power going to the heat pump, so the displayed EV range should go up, right? Nope, stays the same. Any reason, beside another quirk that will never be fixed?
  2. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    It is not intelligent software.
  3. sylvaing
    1,210
    514
    Yeah, and it will never get any brighter either :(
  4. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Could be that turning AC button off and leaving the auto ON keeps the heatpump in the loop . In this mode heating could be provided if the temp in the car is lower than the temp setting . The car does not know your confort level that could call for heat, so a very unprecise estimate of the power needs.:(
  5. sylvaing
    1,210
    514
    That would make sense, if the multi-function display still showed the heat pump as being powered but it isn't. It is shown exactly like when the Climate is turned off.
    Louis19 likes this.
  6. KMO
    KMO Senior Member
    2,018
    743
    Finland
    2023 Prius Prime
    There's no heat pump indication in the display.
  7. sylvaing
    1,210
    514
    What about this?
    It shows energy flowing to it when in Auto On or A/C On, otherwise there is no energy flowing to it.
