Climate Control Display
Discussion in 'Gen 2 Prius Main Forum' started by ssaylor, Apr 8, 2012.
  1. ssaylor
    ssaylor Junior Member
    I need a reality check.
    Lately, in my 2004, with the climate control OFF, and recirculate setting OFF (outside air selection), I seem to still be getting cold air in thru the vents. The air flow selections are all working appropriately between defroster, feet, vent. When I select the OFF button, the fan stops but the last selected air flow stays highlighted - and the OFF button is still black (or, unselected).
    QUESTION - I swear I remember the OFF button highlighting when turning the climate control OFF. Am I just imagining this or could it be the source of my air leak? Is your climate control OFF button highlighted when you turn your climate control off/
    Thanks in advance for verifying...
  2. mdsinger2
    mdsinger2 DynamicBrake
    23
    Virginia
    My 09 does the same thing, I always thought I was crazy but since you brought it up... I second this question
  3. Ophbalance
    Ophbalance Member
    205
    16
    North Carolina
    It happens in my 05 as well. I don't really care as I like having the air flow. I'd hazard it's a design feature and is supposed to be there.
