Climate control error code 97
Discussion in 'Gen 3 Prius Technical Discussion' started by Rubdubb, Oct 12, 2022.
  1. Rubdubb
    Rubdubb Junior Member
    Can anyone tell me what climate control error code 97 and 98 mean?
    My AC stopped working and I assumed the compressor was dead since it has 263000 miles on it but a new compressor didn't change anything. I did the trick to get the ac codes and it's flashing 97 and 98. I can't find these anywhere.
    2010 Prius IV
  2. ChapmanF
    18,947
    Those can be found in the repair manual.
    Toyota Service Information and Where To Find It | PriusChat
    They are trouble codes B1497 and B1498. B1497 is about the electrical bus harness that links the A/C amplifier to the three servos that control different air doors in the heater case (the fresh/recirc inlet, the temperature blend, and the outlet select).
    B1498 is about the circuits that connect the A/C amplifier to the A/C compressor.
    There are around three pages of troubleshooting steps for B1497, and about nine pages for B1498, in the manual.
  3. Rubdubb
    Thank you!
  4. Tombukt2
    Tombukt2 Senior Member
    13,799
    2,501
    Durham NC
    So I guess right now you know it's fully charged and ready to go?
  5. Rubdubb
    Yep. New compressor, evac/recharge
