Climate Control + EV / Eco / Power Buttons Don't Light Up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kepik, Jul 11, 2017.
  1. Kepik
    Kepik Junior Member
    56
    36
    Bay Area, CA
    2013 Prius v wagon
    I've checked all the fuses that are associated with the fuses, the steering wheel buttons are lit as well as my head unit controls. The dimmer switch functions and I'm able to dim everything else.
    But the lights that are associated with buttons on my climate control (the screen works fine) as well as the EV / Eco / Power don't light up anymore when turning on my dash lights.
    How this happened... I was messing around with installing a push button switch
    And shoved the wrong wire in the unused plug of the headlight washer. I was planning to tap the wire that would illuminate my push button switch when the dash lights are turned on.
    Since I couldn't find any fuses and everything else is function properly... did I just screw up those lights?
  2. ChapmanF
    15,494
    The surest way to figure it out is probably to check the wiring diagram, get a positive ID on the washer plug pin position that you did shove the wire into and exactly what circuit that comes from by what path, and, remembering which wire of yours you shoved into it and where that wire went, then start to reason out what the effect might have been.
    -Chap
  3. Kepik
    Kepik Junior Member
    56
    36
    Bay Area, CA
    2013 Prius v wagon
    I had a spare Climate Control unit and I can confirm it's something inside the the ECU. I notice now, when it's dark and my auto headlights activate or parking lights, my dimmer switch, if it's not turned up all the way (where it clicks), the screen on my climate control is complete darkness. Strange thing is, when it's bright and sunny outside, the screen stays on, regardless of the dimmer switch position as well as if my parking and/or headlights are on.
    I should've DL'd all the wiring diagrams when I bought the 2 day thing at techinfo. I'll look into that
  4. Jordan Hieber
    Jordan Hieber New Member
    Charlotte Area
    Ever find a fix?
