Climate control keeps changing the set temperature
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 04 Prius, Aug 4, 2017.
  1. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Hey all I have 2 questions:
    This has been going on since I bought my car 4 years ago. When I shut the car off, the next time I turn it on it seems to always want to readjust itself to be at 74*. I like to keep it @ 70 as it gets stuffy & I get sleepy @74. Is this normal?
    The second question, it keeps alternating the outdoor temperature display in Celsius & Fahrenheit every time I turn the car on, is there a way to keep it on Fahrenheit?
    52,740
    what happens if you shut it off at 74 degrees?
  3. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Never thought to try that......
    'LectroFuel and bisco like this.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Is it in "Auto"? This is not a normal Gen2 action.
  5. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Yes, it's always left in auto unless winter mornings when I need the defrost.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Not at all normal, the controller should retain the pre-set temperature unless the 12v is disconnected or it is physically changed by the operator.
    Again, not normal.
    Putting these two symptoms together, you are likely losing B+ power to the display (controller), or you may not have it at all. Check your fuses as a first step.
  7. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Fuses are good, sometimes on short trips closely spaced it'll retain it for a few trips, then randomly decide it knows better than what I want....
  8. Patrick Wong
    18,210
    6,517
    So if that bugs you, maybe you should replace the AC amplifier. That is the ECU which controls the HVAC system.
  9. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    It is a bit annoying, that said, I've had the car 4 yrs now & it's always done that. I could swap it with one out of my donor car, is it reasonably accessible or a major job?
  10. Patrick Wong
    18,210
    6,517
    I believe the AC amplifier is mounted on the floor of the passenger cabin, below the radio assembly. You would need to remove the plastic trim panel that extends from the floor up to the instrument panel, for access.
  11. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Thank you sir! I shall check into this after I wrap up commissioning the wife's new to us car. (2006 Prius)
  12. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    I decided to attack this while my car was down rebuilding the HV battery, wiring looked ok, replaced the amplifier & haven't had to adjust anything since! Thanks again Patrick!
    valde3 and bisco like this.
  13. Jomarayprius
    Jomarayprius 2010 Prius, 2014 Prius
    Ontario
    Premium w/ Solar Cells
    This is happening on my third Gen Prius also. 2010. Shut off the car, then at cold start up there is minimal display on the temperature control panel, then when you touch a control, like fan speed, the temperature is set to 25 C (in Canada) and you have to put it back down to the temperature you want.
    Think it would be the same fix?
  14. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Hard to know, but as you have 2 Gen 3 Prii, perhaps if you ask your question over in the Gen 3 equivalent forum, the good folk more knowledge in the ways of the Gen 3 may know and be able to help you.
  15. Thakur
    Thakur New Member
    Rochester MN
    XSE
    I went through 100% identical issues. Turned out battery connection were loose. We got replacement battery from orielly autos parts and tech probably was not aware that prius requires battery connection seated really well and need tighten well
  16. dolj
    dolj Senior Member
    8,633
    4,385
    Prius are not special in this regard. All cars need both terminal clamps seated and tightened firmly.
    BiomedO1 likes this.
  17. BiomedO1
    BiomedO1 Senior Member
    4,466
    2,350
    Left Coast
    Yep,
    1. clean both posts and terminals
    2. seat and tighten terminals
    3. spray sealer over both terminals.
    Last step is optional for batteries that live in the passenger compartment of the car, since it isn't exposed to the elements as a battery under the hood is. But it should be a good idea to seal them along with ground points to prevent corrosion / bad contact.
