Climate control question/discussion
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Pizza Driver, Nov 30, 2016.
  1. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    From what I can gather, the Prime uses an electric driven heat pump for climate control. If the ICE is running and the temperature setting calls for heating the cabin, however, wouldn't it make more sense for the car to make use of the waste heat from the ICE rather than to use up electric power? Does the Prime take into account engine coolant temperature and use conventional means of heating rather than an electric powered heat pump?
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Heat is supplied in the conventional manner below 14f where the heat pump cuts off.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yeah, tell that to the annoyed PiP owners that complain about the ICE coming on just because we need a little heat for that less than 10 mile trip.
  4. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    I guess pre-heat is cut off at that stage too right ?
  5. JamesBurke
    1,222
    493
    27
    Morgantown, WV
    Good question. Back to the OM to see what it says.
  6. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    #6 heiwa, Dec 6, 2016
  7. heiwa
    heiwa Active Member
    223
    216
    Central Valley, CA
    #7 heiwa, Dec 6, 2016
  8. bisco
    52,891
    i suspect it switches to engine heat when it's warmer than heat pump.
