Climate Control Question
Discussion in 'Gen 3 Prius Main Forum' started by ddrueckh, Mar 15, 2012.
  1. ddrueckh
    ddrueckh Junior Member
    Castro Valley,ca
    Hi Everyone!
    I have a question about my 2011 Prius II Climate Control. Let's say my climate control if off. I push Auto to turn it on. Next I push the mode button to change it so the air comes out at my feet and windshield. Finally I turn the climate control off with the off button.
    My question is...Is there a way to turn it back on keeping my settings how they were when I turned it off? It seems like the only way to turn it on is to press the Auto button...which changes the mode to either feet or vent. Thanks.
  2. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Why are you turning it off in the first place ?? .... if you want it to come back the same way ... don't turn it off.
    REV
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Are you sure other buttons don't turn it on?
  4. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    You can turn it back on by using the fan speed buttons, I think that keeps it in the 'mode' that you had set.
  5. ddrueckh
    Castro Valley,ca
    True...But remember that when I change the mode everything else is still controlled by the auto...such as the fan speed. If I use the fan speed button to turn it back on then the fan speed is stuck at whatever I set it at and not auto anymore...
    Just seems funny that I can't turn it back on and keep my settings. I need to push auto again and then cycle through the modes until I get what I want.
  6. adamace1
    1,403
    193
    Charlotte, NC
    You can't use auto, and then adjust everything it will come out off auto.
    On my car adjusting anything but temp kicks it out of "auto". So i'm lost when reading your post.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Not entirely... you can adjust the mode which does turn off the auto light but the fan remains in auto mode. Adjusting the fan does remove it from auto entirely.
  8. Tideland Prius
    16,631
    Might be easier to just adjust the temperature to get the MODE you want??
