Climate control while overnighting in your Prime while plugged in
Discussion in 'Prime Main Forum (2017-2022)' started by P.Neophyte, Nov 14, 2020.
  1. P.Neophyte
    P.Neophyte Junior Member
    Fishers, Indiana
    2019 Prius Prime
    I would like to sleep in my 2020 Prime and maintain a constant temp./ climate control while plugged in. Is this possible? This would be above 14º F external temp.
    I assume the ICE will not come on?
  2. Tideland Prius
    16,678
    No. If the car is plugged in, the car will turn itself off after a few minutes (from accessory or IG-ON mode. The car will not go into READY mode).
    The RAV4 Prime has something called "Room Mode" but it was first introduced on the RAV4 Prime.
    P.Neophyte and Merkey like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    As pointed out by @Tideland Prius, having the charge cord connected will essentially disable the ability for the car to go to READY mode. You can use the remote A/C from the fob to turn on the A/C while the car is connected, but it will last only 10min. If you need to camp in a car with climate control ON, then you have to keep the car unplugged and keep it on READY mode. The engine will come on as needed, but that may be better than freezing in the car.
    P.Neophyte and Tideland Prius like this.
  4. David Rush
    David Rush Junior Member
    28
    17
    BC Canada
    2020 Prius Prime
    I tested sleeping overnight in my Prime.
    Outside temp 8 deg C, inside a nice comfy18 deg C.
    Used about 4.5 kw-hrs in 8 hrs based on before/after SOC.
    The prime should be good for overnighting down to near freezing only using the HV battery.
    The biggest problem is significant lack of headroom due to HV battery raising the luggage area floor.
    1x1 and P.Neophyte like this.
  5. P.Neophyte
    Fishers, Indiana
    2019 Prius Prime
    Interesting. I take it that the ICE never started? Do you happen to remember if you had the A/C on re-circulate? At 8 deg C, probably not important, but for summer overnighting here in the southern or eastern states de-humidifying would make it more comfortable at a higher temperature. Did you use a cushioned ground pad of some sort under your sleeping bag?
    Thank you for commenting. Please post more of your experiences.
    You could be like your fellow Canadian, Steve Wallis, on YouTube.
  6. 1x1
    1x1 Member
    147
    45
    It might be possible to set multiple, concurrent charge schedules - each one including the AC(/heat) prep. I think I read that here somewhere, but can't find that particular thread now. Maybe someone can post a link if they know the one I'm talking about.
