Climate Prep not working
Discussion in 'Prime Technical Discussion' started by kevins007, Nov 19, 2017.
  1. kevins007
    kevins007 Active Member
    116
    116
    Milwaukee
    Fellow Humans:
    I live in Wisconsin and for the last few days I have been scheduling my Prime for departure and using climate prep before departure.
    However, nothing happens.
    Car in plugged in to a L2 charger. I lock the car and I even go out to the garage to check on it when it is 10 min before departure and nothing happens.
    I have the heat on high and the Econ setting off. Do I need to turn on the A/C for this to work?
    Thank you.
  2. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Does it appear that the car finished charging, but the climate prep didn’t work? Are you using the Entune app to schedule the climate mode?
    Craig
    HHubbellJR likes this.
  3. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    Are you using the key fob or the Entune app for the Advanced model?
    #1 in Easley,SC
  4. kevins007
    116
    116
    Milwaukee
    No. I am using the setting in the car to set the climate prep. And yes, it has finished charging every time.
  5. Tideland Prius
    16,663
    He said climate prep so he's using the scheduled charging.
    dalcon95 likes this.
  6. CraigM
    208
    208
    Portland, Oregon
    I haven’t tried that method yet. The charge management section in the Entune app looks straightforward, but I haven’t tried the pre-heat function yet.
    I noticed that if I have the car set to finish charging at 8:30, it usually (at least the 2 or 3 times I’ve programmed it) the charge actually finishes 30 or more minutes earlier than that.
    Craig
  7. Tideland Prius
    16,663
    I guess Toyota figures (what if you had to leave earlier?). It wants to ensure you have a full charge close to your original set time.
  8. CraigM
    208
    208
    Portland, Oregon
    I guess. If I ever set the pre-heat, I’d want that to finish at the prescribed time and not 30 minutes early.
    Craig
    Tideland Prius likes this.
  9. kevins007
    116
    116
    Milwaukee
    I figured out the issue that I was having.
    I was using the charge now option in the car when I was scheduling the climate prep at the same time.
    When the charge now option is used, it cancels out the scheduled departure schedule which activates the climate prep.
    Now, what I figured out was that in order for the climate prep to work, I have to schedule the start time for the car to start charging. Then after that the climate prep will start 10 min before the scheduled departure time. My car was nice and warm this morning.
  10. Tideland Prius
    16,663
    I was hoping the two are mutually exclusive. I.e. the climate prep will still work 10 mind prior to departure time.
    So you have to set a start and departure time??
  11. kevins007
    116
    116
    Milwaukee
    Yes you do. I think it is crazy, but that is the way Toyota chose to do it.
  12. Tideland Prius
    16,663
    Wait, this is only if you use the Charge Now option, right?
    If not, then you just leave it plugged in and have it charge using the Departure Time setting?
  13. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    Why not use the Charge Now feature, and 10 minutes before you leave, press the A/C button on the key fob? That means you do not necessarily have to leave at the exact same time every morning, and the car will always be properly conditioned upon entry.
  14. kevins007
    116
    116
    Milwaukee
    I was just trying to figure out how it worked.
  15. Mark57
    2,945
    2,740
    OK
    This is exactly what I do and it works great. I may not always depart at exactly the same time so a manual "A/C Hold" button press guarantees my cabin is warm right before I need it. This way I don't use the heater at all until the HV comes on maximizing my EV range. Obviously, I don't live that far north but it's been in the low 30's here in the early pitch black when I leave.
    Msimardrenaud likes this.
  16. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    Do you still have to have “Charge Now” active if you end up using the “A/C Hold” button daily?
  17. Mark57
    2,945
    2,740
    OK
    All my charging is scheduled, but I don't use the climate prep associated with the schedule because our temps are all over the place. Charge now, is always available if the vehicle is plugged in and not full or currently charging as is using the A/C Hold button. They aren't related to each other.
  18. Acadianer
    Acadianer Member
    123
    82
    Technology
    If I charge the car by Plugging in, remove plug, plug-in again (to start charging right away) after work (since I don’t know if I’m going somewhere after supper), will my schedule climate prep still work in the morning?
  19. Acadianer
    Acadianer Member
    123
    82
    Technology
  20. Acadianer
    Acadianer Member
    123
    82
    Technology
    If I charge the car by Plugging in, remove plug, plug-in again (to start charging right away)after work (since I don’t know if I’m going somewhere after supper)
