Climate scheadule
Discussion in 'Prime Main Forum (2017-2022)' started by RomanCro, Nov 29, 2018.
  1. RomanCro
    RomanCro Junior Member
    63
    Croatia
    2018 Prius PHV
    in low temperatures i have problen wih internal condensation.
    I set up my charge with climate for 7am.
    When i enter my car its all fog and i cant see out, so i must spend 5 mins on vents to clear windows. How can i set up climate to avoid this?
    SM-G950F ?
  2. john1701a
    john1701a Prius Guru
    12,748
    5,243
    57
    Sounds RECIRCULATE is being used. That is a request to not pull in fresh dry air from outside.
    Switch that button off. You'll see a big improvement.
  3. RomanCro
    63
    Croatia
    2018 Prius PHV
    I cant do it if i am.out of the car. Scheadule climate. Not when i am in the car
    SM-G950F ?
  4. john1701a
    12,748
    5,243
    57
    You set it, then leave it that way throughout the winter.
    Mine, here in Minnesota, is always off. That helps prevent moisture.
    #4 john1701a, Nov 29, 2018
    SeattleBicycler likes this.
  5. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    How cold is your low temperatures? If it's below -10C, climate prep is not useful. Heat pump is not effective at that low temp, and climate prep will not turn on ICE.
  6. RomanCro
    63
    Croatia
    2018 Prius PHV
    Now its around 0
    SM-G950F ?
  7. fuzzy1
    10,039
    Is there some store of unwanted moisture inside the car, such as wet carpet, floormats, seats, boots, coats, towels, or something else wet in the cargo area? If so, get it all out. Remove floor mats to dry out inside the house. Completely dry out the carpets.
    If this isn't enough, you may need to use a moisture absorber inside the car, similar to these:
    Then once dried, use the prior advice and keep the car off Recirculate mode while driving.
  8. panache
    panache Junior Member
    28
    Staunton, VA
    If you have the advanced, make sure to turn on the "defrost" on the app. I have the same issue on damp cool mornings. If I notice the windows fogging up while I finish breakfast, I wait for the climate prep to finish and start a new cycle with the defrost on on the app.
  9. RomanCro
    63
    Croatia
    2018 Prius PHV
    I think something is wrong in new cars. I remember, my 1995 car did not have AC. It newer fog my window. Now new cars always make fog inside if you dont use AC. How did all those old cars manage clear windows without AC?
    SM-G950F ?
  10. fuzzy1
    10,039
    Heat.
    AC evaporators can retain some moisture, but AC also encourages some poor moisture-retaining habits with recirculation. But the later is operator practice, not a required part of AC.
    Newer cars are also have better air and weather seals, preventing trapped interior moisture from escaping naturally at the same rate as older leakier car designs.
