clips and bolts for various places
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Aug 25, 2024.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,011
    935
    Southern California
    Took off the front bumper cover yesterday to straighten out the condenser fins. As usual, problems with the fastener hardware.
    1. The radiator cover tray had two types of clips. Two were simple push clips (pry up the simple button to release) and those came out easily. No idea where they came from. Four were generic (ie, not OEM) 90467-06017, the kind with a Philips head center piece that should turn, then pry up. Also supposed to be able to push up from underneath. Nope and nope. The center pin did not extend below the outward clamp legs, and the stupid soft screwdriver slot stripped or wouldn't turn. Had to remove all four destructively (pry up the screw head with a tiny screw driver, grab it and the post with needle nose pliers and lift to release). I had put those on the last time the tray had to come off, when their predecessors disintegrated. On reassembly used some generic Dorman 961-075D 6.4 mm push clips from Advanced Auto. The outer part fit fine, but the push part had to be put in with a lot of force. I'm betting these don't come out easy now, let alone after cooking in the car for a couple of years. I really prefer the simple push pin clips without the screwdriver complication. Anybody know of one of that type that works well in this application?
    2. The 3 clips holding the bumper cover to the radiator support, 52161C, were breaking apart. Tried Dorman 963-552D from Advanced Auto, which are Subaru bumper clips. Both are said to be 9mm. Unfortunately the Dorman clips would not go into the hole, they were a fraction of a millimeter too big. So I put the cruddy ones back in, but since they are not really clamped in there, they need to be replaced. The Dorman 963-125D looks more like the Toyota part, but there weren't any in the store. Also 9mm. Probably. Are 52161C clips 52161-16010, 52161-02020, or some other Toyota part number?
    3. On the bottom of the bumper cover there are bolts with 10 mm heads, a rotating but retained washer, and threads that are very coarse. These go through the loop on the bumper cover into a white plastic retaining clip which is attached to the shield behind it. One bolt was missing, and one screw had a substantially narrower diameter. The skinny one had apparently been driven through both the shield and the white clip, but not in the part where it was supposed to go, just through the plastic flangs. That skinny bolt would not "bite" into the retaining clip, so the car is now two bolts down. What is the part number for this screw/bolt? This might be it, but in the picture it doesn't look as long as the screws on my car (2007):
    90080-15091 - Fender Liner Screw 2000-2024 Toyota | Longo Toyota Parts
    maybe it is this one, seems like a closer length:
    90159-60215 - Bumper Cover Retainer Screw 1996-2023 Toyota | Longo Toyota Parts
    Also what is the part number for those white retaining clips that goes with this screw? I'd like to replace the mangled one at some point. Maybe this?
    90189-06131 - Under Cover Grommet 2006-2009 Toyota Prius | Longo Toyota Parts
    Thanks
    #1 pasadena_commut, Aug 25, 2024
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Amazon and eBay both have sellers that have these boxes that are like $22 and have a hundred some odd of these various clips for Toyota Subaru Nissan etc they're two boxes for the Toyota and believe it or not they have quite a bit of all the popular clips and whatnot in them The white square inserts that push into the square holes that various and sundry wood screw type threaded screw into I usually just pop them out of other vehicles there's plenty around the frame and you can buy those you just have to know what size they are which I don't I don't know if anybody makes an assortment of those but probably but with all the spare cars like I said I just pop them out of other vehicles and other places on the vehicle The screws usually I just have stainless steel ones that I've bought from home Depot or wherever and they're the American equivalent of the metric about the size of a number 9 I guess American if they're a little oversized even better so any waddled out holes in those white square push-ins the oversized screw takes care of that and now I don't have to change the white part
  3. Mendel Leisk
    42,263
  4. pasadena_commut
    3,011
    935
    Southern California
    I have one. That's where the crappy 90467-06017 clips came from. The clips look good, but somehow they don't work well. My guess is that they used a really low quality batch of plastic.
  5. Mendel Leisk
    42,263
    For the ones that survive removal, always rinse them out with soapy water, work the mechanism several times, before reinstall.
    I find a paint can lid pry tool handy for the ones where the centre cap needs to be pried up to release the locking jaws. Sometimes coupled with a slim-blade screwdriver 'round the other side, if stubborn. Patience helps. Pros are tough on them I think, working against the clock.
  6. Tombukt2
    13,809
    2,504
    Durham NC
    Well I've removed mine and put them back in a couple of times the crappy box from Amazon I got a big one The big box I've done four or five cars couple of fender liners all the clips under the hood on the plastic pieces and all of that and I've taken some of that stuff in and out so for me time served and they seem to be okay I try not to be taking this stuff in and out when I have the stuff off and I'm doing work I confirm that everything is fixed before I put all the plastic trim back and have to keep ripping it off We don't do that even if it's a customer's car I'll leave the plastic off and put it in their trunk or put it in my carport while they test the vehicle for a couple of days make certain so on so that we're not just undoing clips and taking stuff on and off continuously just because it seems to work fairly well
  7. pasadena_commut
    3,011
    935
    Southern California
    I use one of these:
    Push Pin Pliers
    works great, the tips are at just the right angle to slide under/pry up the central part.
  8. Mendel Leisk
    42,263
    That does look good. (y)
    see sim on amazon.ca.
  9. pasadena_commut
    3,011
    935
    Southern California
    I obtained some 90467-06017 from Clips and Fasteners
    Screw Type Retainers Toyota Mazda
    which were better quality than the (also) generic ones previously obtained. Bizarrely, these fit into the front 3 holes on the "tray" over the radiator perfectly, but they don't work on the back 3 holes. In the latter case the screw won't advance, it just goes round and round and never goes anywhere. The holes in the back (in the metal pieces under the tray) must be slightly smaller than the ones in front.
    So, I used the Dorman 961-075D in the back. And a few weeks ago I had tested that they could be removed successfully and all 3 came out in one piece and were reinstalled. Today I needed to take the tray off again, and guess what, the Dorman's only come off nicely one time. This second time the "cap" on the center pin broke off two of them. The center pin on this fastener is very narrow, not a huge surprise that it breaks easily. To get them out the "washer" like part above the tray was pried up, and it too snapped off. At that point it was possible to force the remaining part down through the hole. When the tray was put back on new Dorman fasteners were used again, but the center pin was left a few mm up, which hopefully will make pulling them out less traumatic for that center pin. Maybe they can be used twice that way?
  10. Tombukt2
    13,809
    2,504
    Durham NC
    Use the fuzzy stick type they pull and stick better and faster. And reuse 20 times or better.. All this pop up pull out turn a plastic screw . Yada!
  11. pasadena_commut
    3,011
    935
    Southern California
    This sort of thing, 7mm and (have to measure spaces in tray) head diameter?
  12. Paul E. Highway
    Paul E. Highway Active Member
    210
    130
    Hawaii
    Go to the Toyota parts site, they will have diagrams and parts numbers for all these clips and fasteners, then order a dozen of each from Amayama. OEM is best.
  13. pasadena_commut
    3,011
    935
    Southern California
    There is a bit of a trick to using the Dorman 961-075D - don't push the center pin in all the way. I found that if the pin was left about 1/4" out that the force needed to lift that pin out later out was much lower, so that none of the pins broke. Also since the top of the pin is sitting up in the air one can just use a flat bladed screwdriver or a trim tool to lift them up. In that "no quite in" position the clips are still very tight, they are not going to come out.
    That said, the clips taken off the car were much less flexible than those from the same pack which had never been used. That is, the little legs that spread out on the bottom were quite stiff after sitting in the car for months. Both used and unused were at the same temperature too, as both had been sitting on the driveway near each other for half an hour or so. I think this may be a general problem for plastic clips, not just these Dornan's. It will not surprise me if, when removing these again in a year or so, the legs snap off instead of the pin breaking.
