clock in crooked
Discussion in 'Gen 2 Prius Technical Discussion' started by fgoodyear, Mar 31, 2008.
  1. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    I was getting something out of my 07Prius and accidentally hit the clock on the dash. Now one side of the clock is pushed into the dash farther then the other side. Any ideas on an easy - or the best - way to get behind that panel to snap the clock back into the correct position. It's not hurting anything but it is annoying.
    Thanks
    Frank......
  2. SparrowHawk60
    SparrowHawk60 Happy to be green!
    411
    Town of Newburgh, NY, U.S.of A.
    I wonder if you could reach it after you take the glove box out?
  3. tomctomc
    tomctomc Junior Member
    23
    MA
    i have used this trick in the past - but use at your own risk:
    take a pencil or 1/4" dowel and hot-melt glue it to the surface of the pushed in area. Let cool. Pull clock back into place. Scrape off glue. Clearly, the force to pull the thing pack into place cannot exceed the bonding strength of the glue. I specified hot-melt because it is a fairly benign adhesive and scrapes right off most surfaces. Epoxy or crazy-glue would be stronger but you'd ruin the clock face.
  4. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    did the same to my wife's 98 Camry some years back, but her clock was WAY up on the dash, so i asked Toyota to fix it when they were doing some other work. minimal charge.
    probably similar [slightly too-weak] clips holding the prius clock in place, too. Hello, Toyota! :director:
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    If you dig in far enough to remove the MFD, it's attached to
    that same bezel. See the Chris Dragon dash-disassembly guide
    for how to go at it. It's actually not that complex, and on
    the older cars presents a nice opportunity for preventive
    solder touch-up maintenance on the MFD if it's one of the
    vulnerable ones.
    _H*
  6. fgoodyear
    187
    Tillson, New York
    Thanks for the responses. I'll probably try the Chris Dragon method because the clock is in the bezel for the Nav.
    Frank
