Clock not changed?
Discussion in 'Gen 4 Prius Main Forum' started by MaddiKat, Nov 6, 2017.
  1. MaddiKat
    MaddiKat New Member
    I have a 2016 prius and fall daylight savings time just happened but mmy prius's clock hasn't changed? We have the right timezone and have daylight savings checked but the dashboard clock hasnt changed.
  2. Oversplode
    Oversplode Member
    58
    72
    That one has to be changed using the menu in the dash board. Here is a video.
    iPhone ?
    nednvermont and RCO like this.
  3. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    Yeah for some stupid reason the Entune system doesn't talk to the dual screens above. Yet another reason of how badly behind the Entune system is - it should not only keep the two clocks in sync but it should know when DST starts and ends.
    pilotgrrl and RCO like this.
  4. Prodigyplace
    12,711
    11,848
    Central Virginia
    I think that "stupid reason" could be related to my Trim Two that has no Entune system clock or navigation.
    bbald123 and Tande like this.
  5. Tande
    Tande Active Member
    553
    339
    Mich.
    :LOL::ROFLMAO:
  6. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    If you have the "daylight savings time" option the time may correct itself when you turn it off. I have a few digital clocks where that selection advances/falls back the time as it is switched on/off.
  7. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It seems that you have to manually turn "Daylight savings" on and off twice a year on the MFD (Etune) as well as change the clock on the upper display twice a year.
    Yes having two independent clocks neither of which take advantage of the car's communications facilities to stay synchronized to local time is "stupid".
    JeffD
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oh boy! Same in UK. Isn't technology wonderful? :ROFLMAO:
    pilotgrrl likes this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Come to Queensland, Australia - we don't have Daylight Savings time (the closer to the equator, the less useful it is to have it).
    But the nearby state has Daylight Savings - and my phone will click over if I'm close to the border and it links to a tower over the border - the time will change back and forth - just as well I wear a wristwatch.
    pilotgrrl, fuzzy1, RCO and 2 others like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My C-Class used to switch over automatically. Perhaps MB forbade Toyota from copying the system!
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Most clocks that automatically change are either connected to the internet, connected to a phone signal or are radio controlled, the Prius is none of those so it would involve programming the date into the clock and it doesn't.
  12. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    You do program the date into my UK car. It has a calendar apparently. It also has wifi and can access the web via my phone using Bluetooth.
    Further, it has GPS which provides an extremely accurate and high precision clock signal.
    It could make use of any of these to set the clock, but it doesn't seem to.
    pilotgrrl, RCO and Prodigyplace like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    The calendar is for the monthly fuel usage reports so it's not connected to the clock. The wi-fi will connect you to the internet but only to connect the installed apps not the system software and when you're accessing the web via your phone, you're just tethering the phone not the Prius system. You're right about the GPS connected to the NAV but for some reason it still can't communicate the time signal to the main system. It can't be that difficult surely Toyota.
  14. Prodigyplace
    12,711
    11,848
    Central Virginia
    Not all Prius have GPS NAV so that may be their poor excuse for not updating the clock.
    pilotgrrl, RCO and kithmo like this.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    As the date and time are user entered, one way would be to add (in Spring) or subtract (in the Autumn) the hour on a certain date. The only problem is the date varies year to year.
  16. GT4Prius
    530
    412
    Cumbria, UK
    Excel
    It's all one system and if Toyota wanted it would be easy enough to do via any of those channels.
    The clock is not a separate hardware unit like on the Gen2.
    The car can access the web via tethering. For example it can get traffic updates that way if you set out that way. And it can Google search in the Nav for POI destinations.
    But I don't think this is a big deal.
    pilotgrrl, KV55 and RCO like this.
  17. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    The car can get weather and traffic data for the Nav over HD radio. Why couldn't it get the time and update it that way?
    There are probably many other ways to do this.
    To have two clocks that don't communicate through a system in the vehicle is pretty stupid. You're better than this, Toyota!
    RCO likes this.
  18. alanclarkeau
    7,045
    7,593
    Or via the Bluetooth connection when it Syncs the phone?
    RCO likes this.
  19. Prodigyplace
    12,711
    11,848
    Central Virginia
    You had the option of buying one with only one clock. That’s what I did.
    Since2002 likes this.
  20. Priifan
    Priifan Member
    93
    143
    Cary, NC
    The above video was helpful! Will try it, and if it does not work, will go back to Plan B, which always works. Stop by our dealer 5 minutes and no traffic lights away, pop in and ask a young person in service for help checking the pressure in your tires, too. And please tell them how much you appreciate their fine knowledge of the Prius. If you are hungry, they offer free coffee, water bottles and bags of popcorn. A deal hard to beat, especially if you have matching replaced knees and arthritic hands!
    RCO likes this.
