Clock spring and spiral cable trouble
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dummy, May 14, 2026.
  1. Dummy
    Dummy Member
    121
    23
    Colorado
    I’ve been losing function of the steering wheel controls one by one for about 6 months and now I hear crackling when I turn the steering wheel. I actually replaced the clock spring back in 2020 but I can’t remember if the spiral cable was part of that. I used a cheap one and it worked except for the airbag (until now). I’m looking for recommendations on brands of replacement clock springs so I can avoid the short life of the cheap one I bought last time.
  2. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,515
    Durham NC
    Well you'd buy the one from Toyota or amiyama.com if they have it thecheap ones have worked reasonable for me I SE USA. It only takes about 25 minutes to change . So about equal to oil change. Depends on part cost I wouldn't pay 90 for the Toyoda . Personally . These things are too easy to make I don't know thee companies that are racing to bottom . There are ways to quickly sift thru the bs.
  3. ChapmanF
    19,012
    "clock spring" is just what some people colloquially call the spiral cable. They both mean the same part. It kinda looks like a clock spring, even though it's not a spring.
    Dummy and Tombukt2 like this.
  4. Tombukt2
    13,855
    2,515
    Durham NC
    Isn't there a spiral spring along with spiral cable in housing ? You wind with finger to line up red line?
  5. ChapmanF
    19,012
    Not in any I ever took apart. Just a nice flat ribbon cable wound in a spiral.
    Who would want a spring there? Isn't driving in a straight line hard enough already?
  6. Dummy
    Dummy Member
    121
    23
    Colorado
    $350 at dealership
  7. ChapmanF
    19,012
    Just wait'll you price the same part for a gen 3 some day ....
  8. Tombukt2
    13,855
    2,515
    Durham NC
    Yeah I can replace it every year at that price like I say it's a 25-minute job with a 19 mm socket in your fingers oh and the bit for taking the steering pad off in a gen 3 pulling those stupid clips for sterring pad. But a quick job . So I'd buy the 40 or $50 one that somebody makes not the 22 dollar unit .
  9. Tombukt2
    13,855
    2,515
    Durham NC
    I don't understand this I haven't had to replace one on any of my cars yet I had to do a customer's car. And I'm pretty hard on two of my cars their work vehicles they kinda get treated bad . Throw crap in them extended oil services not so much washing. Mechanically solid good AC and wiper blades. And they just go forever. I can't kill them
  10. ChapmanF
    19,012
    In my gen 1, I may have acted early when I noticed a soft card-shuffling (or, well, card-bridging) sound when turning the wheel. I took the spiral cable out and sprayed Elmer's Slide-All on the cable, and put it back in.
    Tombukt2 likes this.
  11. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    And all this time I thought the digital clock in the car was powered by a spring in the steering wheel that you wound up by making three point turns. :)
  12. ChapmanF
    19,012
    A friend's Galaxie 500 had a clock that was powered by a spring. It had a pair of contacts that would close when the spring was close to wound down, and trigger a solenoid that wound it back up. It wasn't in the steering wheel though.
    Sitting quietly in the car, you'd hear it occasionally: ... tick tick tick tick tick tick tick tick GRNCH tick tick tick tick tick tick tick tick ...
  13. PriusCamper
    13,452
    5,430
    I get that ticking when sitting quietly within my own brain... Haven't exploded yet, but I'm only in my mid-50's so maybe I'm being impatient?
  14. Dummy
    Dummy Member
    121
    23
    Colorado
    Next one will be a Tesla
  15. Dummy
    Dummy Member
    121
    23
    Colorado
    You really did that? Should I lubricant the new one before I install it?
  16. ChapmanF
    19,012
    I doubt that there would be any sense in doing anything to a new one before installing it. Would only void the warranty and mess up whatever factory treatment was there.
    Now, if a 15-year-old one with 200,000+ miles on it starts making a bridging-cards noise when you turn the wheel, Slide-All is the stuff I would try. (And did!)
    Dummy likes this.
  17. Dummy
    Dummy Member
    121
    23
    Colorado
    Another quality question. In 2020 I replaced it because the cruise control wasn’t working while all other functions were fine. The cheap one I used fixed the cruise but it caused the airbag light to come on. I had read that was a risk with the cheap clock springs. I’d still like some cheap brand recommendations that at least give all functionality back.
  18. ChapmanF
    19,012
    At least that wasn't the worst case. It made you aware right away that you were going to smack the steering wheel if you crashed.
    Probably the worst case is if the janky spiral cable does carry enough test current to keep the warning light off, but still can't inflate the airbag when you need it.
    Dummy likes this.
  19. Hayslayer
    Hayslayer Active Member
    534
    325
    Cheap is a salvage yard
    Brian1954 likes this.
  20. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Wow, haven't thought about that in decades, but that's the same type of clock in my Dad's Opel Kadette.
    It quit working, and he opened it up to hit the contacts with a points file. Really neat design when I learned about how it worked.
