Clock spring question
Discussion in 'Gen 2 Prius Main Forum' started by CanTG, Nov 20, 2019.
Tags:
  1. CanTG
    CanTG Junior Member
    New to the forum, I’ve been “lurking” for a while since my daughter decided she wanted a used Prius for her first car - wealth of information here!
    She LOVES her “new to her” car, but I noticed about a week ago that her steering wheel defrost buttons aren’t working - research on here suggests the clock spring.
    All other steering wheel buttons work (temperature, volume, etc), and yes, if I turn the wheel 90 degrees to the left - the defrost buttons work.
    My question is - due to the clock spring having something to do with the airbag (???), is this a safety issue? I can live without her being able to control the defrost from the steering wheel - but as a mom, can’t live with it if it could cause an airbag to malfunction!
    (2006 base Prius)
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Airbag is still working fine. If there was any problem with airbag airbag warning light would light up. Yes both functions go through clock spring but separately. Maybe in the future clock spring will fail more and airbag warning light will light up and then airbag might not work. So if you want to be sure you could change it before that but you should use OEM one as aftermarket ones can fail a lot faster.
  3. CanTG
    CanTG Junior Member
    Thank you - this was exactly the info I was looking for!
  4. jrw1621
    jrw1621 Junior Member
    Huron, OH
    My Prius experience has been that the right side buttons will stop working first. These are that round pad that includes the defrost buttons. this could go on for a while before the next thing fails which will be the cruise control functions.
    When the defrost fails it's kinda okay because those are redundant buttons meaning that you can still turn on the defrost, etc through the main screen. When the cruise control fails there is no other way to make the cruise work. It is at this point that I have replaced the clock spring.
    Here is a lead to a good video I found for clock spring replacement...
    The only thing special needed (and it is not that special) is a torx bit. Disconnect the battery! Also, be sure to park the car with the wheels very straight because you will have to put the steering wheel back on very straight when you are done.
    gdanner and Ernie stires like this.
  5. ChapmanF
    19,012
    Or make match marks on the wheel and column shaft before pulling the wheel, and put it back on with the marks aligned.
    ydpplqbd and SFO like this.
  6. Prius RT
    Prius RT Member
    131
    Any suggestion on where to buy 2007 Prius clock spring .
    Toyota OEM is $300
    Dormant is $90
    Amazon $39
    Will Amazon part be good from a safety standpoint ? I don't wanna buy something that could compromise safety
  7. ChapmanF
    19,012
    Experience around here with cheap aftermarket spiral cables seems to be that they work ok for a little while.
    Prius RT likes this.
  8. Prius RT
    Prius RT Member
    131
    What about dorman $90?
  9. Prius RT
    Prius RT Member
    131
    Or used salvaged part Toyota part ?
  10. ChapmanF
    19,012
    I'd probably prefer a used Toyota part, but I'd care about the mileage on the donor car. These are a wear item, getting flexed with every turn of the steering wheel.
  11. Prius RT
    Prius RT Member
    131
    Why would you not recommend dorman?
    Used part - who knows if airbag was already deployed and there is some damage to this part. Yeah they test the used part but it could fail if the clock spring was damaged if airbag was deployed
  12. Prius RT
    Prius RT Member
    131
    This is what I got from a used part seller on ebay.
    Quote
    Yes has been tested and works great the most common problem with these vehicles is when the items module becomes burnt and the air bag on the wheel explodes."
    Quote
    Is the above really true for gen 2 Prius?
  13. ChapmanF
    19,012
    Whether buying an inexpensive aftermarket part, or a used original part, you'll always be assuming some level of risk compared to that of a new original part. The different ways we different people guess at that comparative risk have some personal judgment involved; I've said what my judgment would be, but yours doesn't have to be the same.
    Certainly, if I bought a used spiral cable of any kind, I'd be closely inspecting and bench testing it for any sign it might have been in an airbag deployment, which would lead me to pass on it. Could there be some kind of damage from bag deployment that would leave no trace? Well, maybe, but that's not what I've seen.
  14. Prius RT
    Prius RT Member
    131
    Thanks. Do you know if part# is 84306-0E010 or
    84306-48030
    I am getting 0E010 for $220 online.i believe that is the newer part and original is 48030?
  15. ChapmanF
    19,012
    rogerdpack and Prius RT like this.
  16. Prius RT
    Prius RT Member
    131
  17. Prius RT
    Prius RT Member
    131
    Maybe I am interpreting this wrong.
    84306-0E010 or 8430648030 are the newer part# for the old part# 843060E010
  18. ChapmanF
    19,012
    Are you just asking about the hyphen?
    Toyota part numbers are usually spelled with a hyphen in the middle. Sometimes they aren't. It's the same part number.
  19. Prius RT
    Prius RT Member
    131
    Yeah. I was talking about hyphen.
    84306-0E010(hyphenated) supercedes 843060E010(not hyphenated) per the link you sent. That would mean the newer part# is 84306-0E010(hyphenated).
  20. ChapmanF
    19,012
    Yeah, no. If you poke around the Toyota parts site enough, you'll see for every part that its 'supersession' list includes an entry for itself, spelled without the hyphen. Kind of an amusing pattern ... maybe it helps find the right entry when somebody searches for the number without the hyphen.
