Cloudy/Blurry AC screen?
Discussion in 'Gen 3 Prius Main Forum' started by Morgank6, Jul 7, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'll refrain from my photo then as the two side-by-side would be far more useful (and it's 108°F outside still)
  2. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Mine seem to be perfect, no cloudiness at all:
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Your first picture (of the A/C display) has the same matte surface texture as mine--including the scratches (which mine had when I took delivery), contrasted with the second picture (of the audio display). I can see the difference in clarity--the audio display has blacker/clearer numbers.
  4. HTMLSpinnr
    5,341
    920
    251
    This is about what my A/C panel looks like as well.
  5. IraS
    IraS Member
    165
    50
    Austin, TX
    Mine looks about the same.
    It is readable, but not crisp. It looks like there is an anti-glare screen, which is causing the lack of clarity.
  6. nylion
    nylion New Member
    167
    61
    Seattle WA
    Based on the photos submitted, I think that everyone's screen has the matte finish. This isn't unusual. It really cuts down glare. The difference between the "sharp" images and teh "blurry" ones is LCD conrast. LCD screens usually have a contrast control that allows darkening the blacks, thus improving contrast. Go too far and the background darkens. I don't know of any control for this on the car.
    It should be noted that LCD's are also temperature sensitive. Cold slows down response and heat increases contrast. Have you noticed that devices with LCD displays left in the sun or in a hot room, have a "black" display? Could this problem be thermal? It is summer here.
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Mine has the same problem - lower screen is more blurry than the top. I'm a weather nut and it's annoying to say the least to strain to read the outside temperature!
  8. loopybunny
    loopybunny team autobus
    17
    northern california
    Thank goodness it's not just mine!
  9. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Here is my display.
    Inside the garage, using flash on my camera.
    Outside the garage, using flash on my camera.
    Outside the garage, no flash.
    :noidea:
  10. DetPrius
    545
    92
    Southeast Michigan
    Wow dmvp, seeing your pictures convinces me there is something wrong with mine, although I wonder if there is anything going on with the fact that I'm looking at a photo and not looking at personally.
  11. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Mine's cloudy/blurry and all along I assumed it had a plastic film on it.
  12. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yours looks blurry to me. dmvp's pics look clear. I don't know what's going on.
  13. dfran1
    dfran1 New Member
    89
    17
    MA
    Hi all,
    Thank You for posting and keep em coming please!
    My appointment is Friday for them to look at it, well see how it goes, but I suggest all to get a dealer to look at it.
    I am starting to get prepared and hope this gets fixed with little effort on my (our) part.
    Dmvp yours looks perfect, the rest so far is cloudy (blurry). THANK YOU FOR POSTING!!!
    Keep posting please!!
    !!!!!Thank You!!!!!
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Sorry all, something came up and I just got back on today :redface: Tomorrow I will definitely take pics of mine and my dads to compare the difference between the two. I don't want to take them now with the backlight on, I think it'll be better in daylight to do it.
  15. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Ok, here's a pic of my dad's and mine... His says 90 degrees and mine says 84...
    His, the blurry one:
    Mine, not blurry, just has slight lines on the front which I guess is the coating for glare...
  16. onbypass
    onbypass New Member
    Suffolk, VA
    I've got a V with Nav.... and YES..... mine definitely looks blurry, too. I will try and post some pics.
  17. nylion
    nylion New Member
    167
    61
    Seattle WA
    I was wrong before. The AC screen is almost unreadable. Now that I have my V AT, I am sorry to report that I too can barely read this display. I hope we can figure out how to get this corrected.
  18. LAPriusIV20
    LAPriusIV20 New Member
    30
    Los Angeles
    Same problem. It looks like there is a film cover, but there is not...
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Looks like it's crap across the board. I can see them replacing a few defective units, but this will have just as much luck as trying to get them to replace the crappy NAV screen.
  20. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Looks like it has some sort of coating on the display screen, which causes the distortion and blurry. May be able to use plastic polish or rubbing compound to remove the coating.
